Old 10-28-2017, 02:32 PM
Capote Capote is offline
Registered User
DK2 camera position
I'm using the Vizard software along with the oculus rift Dk2. the fact is that I have 2 problems. the first is that the positional tracker does not work and I do not know which command to configure. the second is that the camera has to be behind the point of view and I would like it to be in front. How can I change it?
thank you very much to who can help me
Old 11-14-2017, 11:25 PM
To get the DK2 working with Vizard, make sure you follow the getting started section in the Oculus page. As a first test to see if it's working with Vizard, run the oculusExample script referenced in that page.
AR Marker Camera Matrix Transform Problem. pwsnow Vizard 11 06-30-2014 05:48 PM
Changing parent without changing absolute global position? The SundanceKid Vizard 2 05-23-2014 03:43 PM
Getting updated position Anastaggra Vizard 1 02-01-2014 01:15 AM
Camera Position And Viztask kovitch Vizard 2 01-11-2011 07:36 AM
Getting camera position from ive TarkaDahl Vizard 1 05-13-2010 02:25 PM
