Old 01-10-2011, 10:23 AM
kovitch kovitch is offline
Camera Position And Viztask
I have a simple script that makes the camera move forward in my scene. The camera moves through some balls. Now I want to accomplish a task every time the camera's position surpasses the ball's.
I use the following lines to move the camera:
class AmblioCameraHandler( viz.CameraHandler ):
	def _camUpdate( self, e ):
		e.view.move( 0, 0, speed)
Nextly, I need to get the cameras position by doing:
cam_pos = viz.MainView.getPosition()
And then I need to compare it with the ball's z coord.
How can I do that using this viztask method?
Best regards!
Old 01-10-2011, 05:36 PM
You can create you own custom condition that checks the position of the viewpoint in relation to the balls. The following page has a section on writing a viztask condition:
http://www.worldviz.com/vizhelp/VizTask_basics.htm
Old 01-11-2011, 06:36 AM
That did the trick. Thanks!
.clone() or .copy() durf Vizard 8 04-01-2009 08:45 PM
