Old 05-13-2010, 02:38 AM
Getting camera position from ive
Hi All
Im trying to get the camera position from an .ive file.
i thought the following code would work
modela = viz.add("Test.ive")
print modela.getChild("Camera01").getPosition()
However it only returns [0.0, 0.0, 0,0]
Is there a way of doing this?
Old 05-13-2010, 01:25 PM
The camera data is not exported. One way of doing this is create a box and link it to the camera in Max. You could make the box invisible in Max by assigning a fully transparent material to it or you could make the box invisible in Vizard. Then you can use the GEODE of the box to get the camera position. Take a look at the following kb article which talks about getting a handle to a GEODE.
http://kb.worldviz.com/articles/1157
Connecting vizard to a camera dan12345 Vizard 1 11-11-2008 03:09 PM
default start position erchrastil Vizard 2 06-23-2008 08:15 AM
position of html-file on screen active_world Vizard 1 05-16-2008 07:24 PM
Avatar always returns in initial position pattie Vizard 2 08-31-2006 08:15 PM
