Old 01-29-2014, 08:10 AM
Anastaggra Anastaggra is offline
Getting updated position
Hi all,
I am new to Vizard and still learning..
So, I am trying to move point of view from one position to another position using fluid movement (vizact.goto) and after the view point is moved to a new location, I need to get the the new coordinate of the view.
I wrote the following code:
viz.MainView.setPosition([10,2,3])
view = viz.MainView #grab the coordinate of main view
seq1 = vizact.goto([10,2,15]),3,viz.SPEED, pivot = [0,2,0], ori_mask = viz.BODY_ORI)
#execute action on key down
vizact.onkeydown(' ', view.runAction, seq1)
#get the current position after movement of view point
x,y,z = view.getPosition()
print "Your current position is", x,y,z
The problem is, instead of getting the position of view after the goto command ([10,2,15]), the getPosition always return the original position.
Is there any way that I can update the coordinate of the variable 'view' each time after an action is executed.
Thank you very much for all your help.
Old 02-01-2014, 01:15 AM
Hi Anastaggra,
There is a simple solution for your problem. The problem is that with the code you provided, your variables x,y, and z are set once the code runs, and not updated when the position of the viewpoint is updated. What you need to do is to update x,y, and z after you have pressed the spacebar. So instead of running only the action, you also need to update x,y, and z. See below for an example using a sample environment that comes with Vizard:
viz.add('gallery.ive')
viz.MainView.setPosition([0,1,0])
seq1 = vizact.goto([0,2,2],3,viz.SPEED, pivot = [0,2,0], ori_mask = viz.BODY_ORI)
def moveView():
	view.runAction(seq1)
vizact.onkeydown(' ', moveView)
Good luck!
Frank
Set Mouse Position javadi Vizard 2 11-19-2013 04:59 AM
How to pass only 1 axis of the position signal from the source to the dest in a LINK? Zhi Vizard 2 04-04-2013 08:28 AM
Getting Position Lynnifer Vizard 1 07-16-2012 10:49 AM
Dynamic Position and Radius of Sphere hotshotiguana Vizard 1 03-23-2011 01:53 PM
writing joystick position to a data file Saz Vizard 3 12-17-2008 06:18 AM
