Old 10-12-2010, 10:24 AM
Exclamation textures bug/problem?
I have to choose between to methods of applying a texture.
I would like to use A, but the resolution is MUCH lower than B. Why? How do I make is as good? Thanks
Method A:
pngData = cStringIO.StringIO()
pylab.savefig(pngData, format='png')
pylab.close()
T = viz.addBlankTexture([1, 1])
T.loadBuffer('.png', pngData.getvalue())
TMP = vr_world.getChild("object")
TMP.texture(T)
Method B:
pngData = "mydo_chart.png"
pylab.close()
T = viz.add(pngData)
TMP.texture(T)
Old 10-12-2010, 03:12 PM
How much lower is the resolution? Add the following line at the end of each sample to see what the images sizes are:
print T.getSize()
Textures not loading properly and offset window TarkaDahl Vizard 2 05-18-2010 01:54 PM
Textures Scrambled lionfish Vizard 3 02-26-2010 01:42 AM
Multiple Textures for Diffuse and Specularity Shader Issue shivanangel Vizard 1 05-11-2009 10:44 AM
Max -> Vizard, Two Sided Textures shivanangel Vizard 5 12-04-2008 03:15 AM
Overlaying Textures with Alpha Masks vjosh Vizard 7 04-06-2005 07:46 PM
