Old 05-18-2010, 03:18 AM
Textures not loading properly and offset window
Hi all,
Ive just installed viz on a newly installed pc and put on our new license key. however when i run the code i have a windows offset as explained here http://forum.worldviz.com/showthread...hlight=windows
also now textures are not loading properly the textures are being replaced by textures that have been previously removed and are using textures from models which have been removed in places where i have loaded. similar to what is explained here http://forum.worldviz.com/showthread...hlight=texture
Old 05-18-2010, 10:22 AM
Are you using an ATI graphics card? They are notorious for having buggy OpenGL drivers. I've seen the window offset issue with ATI cards before. We will try to find a work around for this in the next release. In the meantime, make sure you have the latest drivers installed.
Old 05-18-2010, 01:54 PM
thank farshizzo
your right it was an ati card. we put the licence on another machine and it worked like a charm.
i got a bit stressed about it but everything is ok now.
thanks
