Old 04-01-2005, 02:10 PM
vjosh vjosh is offline
Overlaying Textures with Alpha Masks
Hey,
I need to overlay one or more textures with alpha masks on top of an object's original texture within Vizard. Will multitexturing work for this? What blend settings should I use? Ideally, the alpha masks on the additional textures would dictate how the textures are blended...
I'm also having problems with texturing faces. I looked at a previous post that suggested using the following code in order to make the texture coordinates work:
newtexture = viz.add(texture)
newtexture.wrap(viz.WRAP_S,viz.REPEAT)
newtexture.wrap(viz.WRAP_T,viz.REPEAT)
This works when applying the texture to the default layer (textureNum 0) with the following code for example:
self.head.texture(newtexture, 'geom_0')
But it doesn't seem to work correctly for code like this (regardless of how I blend the textures afterwards):
self.head.texture(newtexture, 'geom_0', 1)
Any suggestions?
-Josh
Old 04-01-2005, 03:17 PM
Hi Josh,
Take a look at the following forum post:
http://www.worldviz.com/forum/showth...3?threadid=141
At the very end of the post I include a link to a plugin that allows the user to specify a grayscale mask for blending two textures. If this doesn't suit your needs then let me know exactly what you want and I'll change it for you.
Old 04-01-2005, 03:35 PM
Hey Farshizzo,
Thanks. I might need something a little more... I'm trying to overlay a few mud splotches on top of the default texture of an object, but they need to be erasable on an individual basis. It seems the easiest way would be to create images of mud spots on individual textures with alpha masks so the original texture shows through. Then I could just remove each individual mud spot by removing the particular texture. Does this sound feasible?
I suppose the grayscale mask could be made to work (though probably a bit more cumbersome). But I need to be able to blend an arbitrary number of textures...
Thanks again!
-Josh
Old 04-01-2005, 03:44 PM
Hi Josh,
What is the maximum number of textures you will be applying at a time? The reason I ask is because your video card has a limit to the number of textures you can apply to an object. Usually this limit is 4.
Old 04-01-2005, 04:00 PM
Hey Farshizzo,
I'm not sure what the limit is on the video card I'll be using. If the limit is 4 then that will have to suffice. Otherwise, it'd be nice to have as many as 10 or so. Is the limit in effect for each geom subchild or does it count against the object as a whole?
-Josh
Old 04-01-2005, 05:21 PM
Oh, one thing I forgot to mention... It would be nice to be able to change the opacity of the mud texture dynamically if possible (i.e. make it fade away). If there's no easy way to do this then I suppose I could use multiple textures with slightly different alpha masks.
Old 04-05-2005, 10:55 AM
Hi Josh,
Do you need to postion these textures at a specific point on the object or just apply it onto the entire object? Also, is the object that you want to apply these textures flat or curved?
Old 04-06-2005, 07:46 PM
Hey Farshizzo,
The object(s) will be curved. In fact, one particular object will be a human (so I'll need to be able to texture custom faces as well). I'm not sure what placing the textures at a point would involve. Perhaps the most straightforward way for me is to look at whatever texture is currently being used for an object and draw in what I need at a particular location on the texture (while alpha masking everywhere else). So it'd be great if the overlaid textures were mapped over the existing texture in the same exact way.
-Josh
