Old 11-04-2013, 11:30 AM
Question vizjoy.py Twist method
Going over some old code and I had a question.
Years ago, I modified vizjoy.py for the twist method.
The original method is:
def getTwist(self):
	"""Returns the twist of the joystick"""
	return self.getRotation()[2]
My new method hardly changed anything:
def getTwist(self):
Why do you only return the second element of the joystick? For other hardware such as the XBoxController with 2 sticks, I can't directly query the state without this information or utilize the overwritten callback to twist that is in your documentation.
That is, I wouldn't be able to do the following with only one element being passed from getTwist
def twist(self, val):
	self.xRAccel = 0.0
	self.yRAccel = 0.0
	if (abs(val.twist[0]) >= self.deadZone):
		self.xRAccel = val.twist[0]
	if (abs(val.twist[1]) >= self.deadZone):
		self.yRAccel = val.twist[1]
Is there something I am missing? Is there another method someplace to get this information about the second analog stick?
Old 11-05-2013, 10:13 AM
If you want all rotation values, then simply call joy.getRotation() instead of joy.getTwist(). As shown in the code you posted, getTwist is simply a convenience method to get the Z-rotation value of the joystick. There is no need to modify vizjoy.
vizjoy, xbox controller
viz.Vector and normalize method shivanangel Vizard 1 08-02-2013 10:07 AM
morphTo: Is there a smoother method? Josh Vizard 1 03-08-2010 10:50 AM
read method needed Woosuk Jang Vizard 3 06-22-2009 06:49 PM
parallel port method bionic1 Vizard 2 05-04-2009 07:41 PM
mapping method FlyingFish Vizard 1 07-12-2007 10:06 AM
