Old 07-27-2013, 03:41 PM
Thumbs up viz.Vector and normalize method
Vizard Support,
This is a suggestion and not a question.
Any chance you could make the normalize method in the viz.Vector class return the normalized vector so we can use the result in a single lined expression?
So I can do things like this in one line:
circleVec = (viz.Vector(1,0,0) + viz.Vector(0,1,0)).normalize() + offsetFromCenterVector
It has always kind of bothered me that I can't do this, especially after writing GLSL code where I get the result of the normalized vector in an expression.
George
Old 08-02-2013, 10:07 AM
Thanks for the suggestion. In a future version vector.normalize will return itself so it can be passed directly to a function. However, you can currently normalize a vector during creation:
v = viz.Vector([0,3,0],normalize=True)
You can also set the length to a specific value:
v = viz.Vector([0,3,0],length=5)
normalize, suggestion, viz.vector
morphTo: Is there a smoother method? Josh Vizard 1 03-08-2010 10:50 AM
read method needed Woosuk Jang Vizard 3 06-22-2009 06:49 PM
parallel port method bionic1 Vizard 2 05-04-2009 07:41 PM
mapping method FlyingFish Vizard 1 07-12-2007 10:06 AM
method of a class instance not accepted as Callback Gilliard Vizard 1 08-10-2005 06:49 PM
