Old 03-07-2010, 04:20 PM
Josh Josh is offline
morphTo: Is there a smoother method?
Hi all
morphTo is very unnatural: it's always at the same speed. It would be better to start slowly, then incrementally get faster, and then incrementally get slower again until the morph has completed.
Is there maybe some method that does this?
Thanks for help :-)
Josh
Old 03-08-2010, 10:50 AM
You could break up the vizact.morphTo action into a sequence of shorter morphs. For each one you could pass in a different time value.
setEuler method of Shadow module omidbrb Vizard 1 02-22-2010 10:35 AM
read method needed Woosuk Jang Vizard 3 06-22-2009 06:49 PM
parallel port method bionic1 Vizard 2 05-04-2009 07:41 PM
mapping method FlyingFish Vizard 1 07-12-2007 10:06 AM
method of a class instance not accepted as Callback Gilliard Vizard 1 08-10-2005 06:49 PM
