Old 09-09-2013, 06:30 PM
Dirtpickle Dirtpickle is offline
Problems with textures
I'm new to vizard I don't know how to view my models in the viewer so I've been using the inspector to see if my models will work in vizard. What I see is major texture distortion. I don't know how to fix. I've tried all kinds of things. I'm using 3ds max with the osg plugin. I've ticked all of the proper settings for the export but i keep getting the same results.
Thanks for any help you can provide.
Here is what im getting:
Old 09-11-2013, 02:53 PM
What image format are you using for your textures? Can you send the 3ds Max model to support@worldviz.com?
Old 09-14-2013, 12:06 AM
I've been using *.tif. I was rendering to texture the shadows and this seems to be the only image format it will export. I havn't tried to change it post render. I'll give that a shot and see what happens.
Missing textures in an executable Dave Vizard 7 10-22-2010 08:59 AM
Textures not loading properly and offset window TarkaDahl Vizard 2 05-18-2010 02:54 PM
Multiple Textures for Diffuse and Specularity Shader Issue shivanangel Vizard 1 05-11-2009 11:44 AM
Max -> Vizard, Two Sided Textures shivanangel Vizard 5 12-04-2008 04:15 AM
Overlaying Textures with Alpha Masks vjosh Vizard 7 04-06-2005 08:46 PM
