Old 07-05-2011, 10:28 PM
Chapre Chapre is offline
Question Hotspot trigger
Hello;
How to make a hotspot be triggered by an other object (3D node) different to the active viewpoint?
Old 07-07-2011, 11:27 AM
Hotspots only work with viewpoints. You can check the distance between an object and a location in the scene using the vizmat.Distance command. This could be done frame or on some other regular interval using a timer function.
External Trigger via LabJack ursi Plug-in development 10 01-21-2010 11:57 AM
hotspot nlfrnassimi Vizard 1 03-17-2009 01:34 AM
collision events trigger Eunice Vizard 1 01-03-2006 11:39 AM
triggering actions on proximity exhale Vizard 3 03-14-2005 03:26 AM
A hotspot id of -1 will never trigger. jrodman Vizard 1 01-27-2004 04:22 PM
