Old 03-17-2009, 12:30 AM
hotspot
I have created a character and a view is connected to it. There is a hot spot defined for the car. When view gets close a page appears. How can I define that when it comes out of the hotspot the page disappears again?
here is the code:
viz.clearcolor(0.5,0.5,1)
MOVE_SPEED = 5 # how fast the viewpoint move
TURN_SPEED = 60 # how fast the view point rotate
viz.add('tut_ground.wrl')
char = viz.add('vcc_male.cfg')
char.state(1)
intro = viz.add('front.3Ds')
intro.translate(0,0,100)
intro.visible(viz.OFF)
view = viz.MainView
view.setPosition(0,1.7,0)
car = viz.add('mini.osgx')
car.setPosition(5,0,10)
def mytimer(num):
	if viz.iskeydown(viz.KEY_DOWN):
		view.move(0,0,-MOVE_SPEED*viz.elapsed(),viz.BODY_ORI)
	elif viz.iskeydown(viz.KEY_UP):
		view.move(0,0,MOVE_SPEED*viz.elapsed(),viz.BODY_ORI)
		view.rotate(0,1,0,TURN_SPEED*viz.elapsed(),viz.BODY_ORI,viz.REL_PARENT)
		view.rotate(0,1,0,-TURN_SPEED*viz.elapsed(),viz.BODY_ORI,viz.REL_PARENT)
	updatechar()
def updatechar():
#translate the character to the position of the viewpoint
#  char.translate(view.get(viz.HEAD_POS))
#rotate the character to the same orientation as the BODY_ORI.
  char.rotate(view.get(viz.BODY_AXISANGLE))
#move the character beside the view.
  char.translate(1,0,0,viz.REL_LOCAL) #viz.REL_LOCAL. This tells vizard to translate the car relative to its local coordinate system (i.e. relative to the direction the car is facing).
def mousemove(e):
	#gets the Euler angle rotation of the HEAD_ORI
	euler = view.get(viz.HEAD_EULER)
	#adding the x movement of the mouse to the current yaw(we multiply the x movement by 0.1.  This is to decrease the sensitivity of the movement)
	euler[0] += e.dx*0.1
	#adds the y movement of the mouse to the current pitch. We need to negate the value since a positive pitch value means rotating down, but moving the mouse down means having a negative y movement.
	euler[1] += -e.dy*0.1
	#clamping the pitch value between -90 and 90, since we don't want to let the user look down or up so much that they end up upside down.
	euler[1] = viz.clamp(euler[1],-90.0,90.0)
	#rotating the HEAD_ORI of the viewpoint by the new euler angle rotation
	view.rotate(euler,viz.HEAD_ORI)
viz.callback(viz.MOUSE_MOVE_EVENT,mousemove)
#Turn off built in  mouse
viz.setMouseOverride()
#Hide cursor
viz.cursor(viz.OFF)
def mousedown(button):
		view.reset(viz.HEAD_ORI)
	elif button == viz.MOUSEBUTTON_RIGHT:
		view.reset(viz.BODY_ORI|viz.HEAD_POS)
	updatechar()
viz.callback(viz.MOUSEBUTTON_EVENT,mousedown)
VIEW = 1
def onHotspot (id,x,y,z):
	if id == VIEW :
		intro.visible(viz.ON)
	else :
#Callback the hotspot event.
viz.callback(viz.HOTSPOT_EVENT,onHotspot)
#Attach a hotspot to the duck.
car.starthotspot(VIEW, viz.CIRCLE_HOTSPOT_IN, 5,0,10)
Old 03-17-2009, 12:34 AM
can any one please tell me how to do the same thing by using getPOsition instead of hotspot?
physics nlfrnassimi Vizard 3 03-18-2009 08:47 PM
Hotspots and Video eirc Vizard 3 01-29-2008 08:58 AM
Coldspots? codexter Vizard 1 02-20-2007 03:11 PM
triggering actions on proximity exhale Vizard 3 03-14-2005 02:26 AM
A hotspot id of -1 will never trigger. jrodman Vizard 1 01-27-2004 03:22 PM
