Old 01-15-2010, 11:53 AM
ursi ursi is offline
External Trigger via LabJack
I wanna trigger a Vizard-function via an external trigger (via LabJack). How do I do that?
I wrote the following code using 'vizact.waitsignal':
import u12
d = u12.U12()
Trigg = d.eAnalogIn(0)
#Create the signal object
sig = vizact.signal(Trigg > 0)
#Create an action to wait on the signal
waitsig = vizact.waitsignal(sig)
def ExtTrigg(waitsig)
### add SOUND
song = viz.add('Beethoven.wma')
song.loop(viz.OFF)
#viz.callback(viz.Event,ExtTrigg) ##?
viz.callback(viz.ACTION_BEGIN_EVENT,ExtTrigg) ##?
Old 01-15-2010, 04:11 PM
You could use vizact.onupdate to check every frame if the trigger has occurred and then either do something there or call another function
def checkTrigger():
	trigg = d.eAnalogIn(0)
	if trigg > 0:
		ExtTrigg()
vizact.onupdate(0, checkTrigger)
Old 01-18-2010, 12:04 PM
And the callback function is ok or do I have to callback also the 'checkTrigger' function?
### add SOUND
song.loop(viz.OFF)
def checkTrigger():
if trigg > 0:
ExtTrigg()
Old 01-18-2010, 06:06 PM
The line of code
already registers the checkTrigger function and that will be called every frame. Have you tried running that on it's own without the code you added?
Old 01-19-2010, 05:17 PM
Hi
I tried it like that to keep it simple:
import u12
d = u12.U12()
trigg = d.eAnalogIn(0) # AI0
def ExtTrigg():
print trigg
def checkTrigger():
if trigg > 2.0:
ExtTrigg()
But it gives me this output (ever and ever again; regardless if I change my if-condition to 2.0, what should call the ExtTrigg-function):
{'overVoltage': 0, 'idnum': 0, 'voltage': 1.4208984375}
I can't read in a external voltage into AI0 (a ramp 0V-5V-0V produced by a battery). My output in Vizard is always unchanged by 1.42...V.
Do I also have to address my output like ' if trigg{3} > 2.0' or similar? I tried that, but it didn't seem to work with either [] nor () or {}.
I just have some background in Matlab, so I don't have a clue, what I could try next in Python...
Old 01-20-2010, 10:42 AM
Please use the code tags when you post code to preserve the indentation. This line
should be inside your checkTrigger function if you want to be continuously checking it.
Old 01-20-2010, 01:06 PM
The problem still remains...
def ExtTrigg():
	print 'trigger > 2.0'
def checkTrigger():
	if trigg > 2.0:
		ExtTrigg()
How can I address the 'right' output to be checked?
Why does it not work to feed in a voltage?
Old 01-20-2010, 05:40 PM
What do you get if you try the following? This should print out the voltage once a second. Do you notice any errors in Vizard's input/output window?
def checkTrigger():
	print trigg['voltage']
vizact.ontimer(1, checkTrigger)
Old 01-21-2010, 10:39 AM
I can now feed in 'my' voltage from the external source and print just the voltage output. So, that works fine, thanks.
But it prints the result still every second, so the if-condition does not seem to work properly...
def ExtTrigg():
def checkTrigger():
	if trigg > 2.0:
		ExtTrigg()
Another question: can I chance the code, so that the frequence for checking the trigger would be higher than once a second?
Old 01-21-2010, 11:55 AM
Ok, I see, that the if-condition work fine, if I address the voltage output...
if trigg['voltage'] > 0.2:
So, the last question that remains is the higher frequency for checking the trigger?
Old 01-21-2010, 11:57 AM
Sorry, I figured it out...
vizact.ontimer(.01, checkTrigger)
Implement LabJack ursi Vizard 4 01-07-2010 04:14 PM
Updating viewpoint via external computer Rachel Vizard 1 02-04-2008 07:23 PM
labjack plugin Jerry Vizard 1 03-14-2007 05:36 PM
collision events trigger Eunice Vizard 1 01-03-2006 11:39 AM
A hotspot id of -1 will never trigger. jrodman Vizard 1 01-27-2004 04:22 PM
