Old 04-27-2010, 02:17 PM
JimC JimC is offline
Question Navigation problem
Hi all,
I have a simple CAVE navigator: You point the tracked wand in the direction you want to fly and push the joystick forward. It's implemented by linking the following to the CaveView object:
class SyzygyNagivator(viz.VizNode,viz.EventClass):
  # __init__ omitted
  def onUpdate(self,e):
    currTime = time.clock()
    elapsed = currTime - self.lastTime
    if elapsed < .25:
      # Get joystick X,Z values and threshold them
      xMove = self.service.getAxis( self.xIndex )
      if abs(xMove) < .25:
        xMove = 0.
      zMove = self.service.getAxis( self.zIndex )
      if abs(zMove) < .25:
        zMove = 0.
      # Get wand orientation matrix
      rotMat = szg.ar_extractRotationMatrix( self.service.getMatrix( self.matIndex ) )
      # Compute rotated X, Z motion vectors
      xVec = rotMat * szg.arVector3(0,0,zMove)
      zVec = rotMat * szg.arVector3(xMove,0,0)
      # Add them
      vec = (xVec + zVec).toTuple()
      # Displace by motion vector
      currPos = gCaveView.getPosition()
      newPos = vizmat.MoveAlongVector( currPos, vec, elapsed*self.speed )
      self.setPosition( newPos )
    self.lastTime = currTime
...which works fine for flying around in empty space. The catch is that in e.g. gallery.py, when I collide with a well the stored position keeps incrementing as long as I hold the joystick forward, even though the collision detection is keeping the viewpoint from moving forward. In other words, the CaveView object's position does not reflect the action of the collision-handling algorithm. Of course, when you reverse direction, nothing happens until the stored position gets back inside the gallery. What's the right way to do this, i.e. where is there a position that reflects the collision detection?
Some Problem in navigation ssaha Vizard 3 03-24-2010 02:21 PM
Vertex shader performance problem Joran Vizard 2 11-17-2008 02:29 AM
navigation in cave environment Andy Vizard 4 03-28-2008 02:32 AM
5DT Data Glove 5 Ultra Problem bjgold Vizard 1 08-08-2006 05:08 PM
