Old 11-14-2008, 07:45 AM
Joran Joran is offline
Send a message via Yahoo to Joran
Vertex shader performance problem
I have just started experimenting with vertex shaders and I have a performance problem. Below is an example program that shows my problem:
import vizshape
vizshape.addGrid()
viz.MainView.setPosition(0, 1, -5)
vert = """
uniform float elapsedTime;
void main() {
  if( gl_MultiTexCoord0.y > 0.0) {
    gl_Vertex.x += sin(gl_Vertex.x * 0.2 + elapsedTime * 1.0) * gl_MultiTexCoord0.y * 0.2;
    gl_Vertex.z += sin(gl_Vertex.y * 0.2 + elapsedTime * 1.0) * gl_MultiTexCoord0.y * 0.2;
  gl_FrontColor = gl_Color;
  gl_Position = gl_ModelViewProjectionMatrix * gl_Vertex;
shape = vizshape.addQuad()
elapsedTime = viz.addUniformFloat('elapsedTime', viz.tick())
shader = viz.addShader(vert = vert, uniforms = [elapsedTime])
shape.apply(shader)
def onUpdate(e):
	elapsedTime.set(viz.tick())
viz.callback(viz.UPDATE_EVENT,onUpdate)
My problem is that when you check the statistics the Draw time is 15.00 (On my system), while it should be something like 0.02. If I do not update the elapsedTime uniform every frame, the performance is fine (but I have no animation). What am I doing wrong?
Greetings, Joran.
Old 11-14-2008, 02:22 PM
I don't think you are doing anything wrong. I tried your sample code and my draw time is 0.04 using a GeForce 8800 GTS. This might be an issue with your OpenGL drivers.
FYI, you don't have to create your own elapsed time uniform. OpenSceneGraph supplies the following global uniforms that you can use in any shader:
int osg_FrameNumber;
float osg_FrameTime;
float osg_DeltaFrameTime;
So you can modify your example to use this global uniform instead:
import vizshape
vizshape.addGrid()
vert = """
uniform float osg_FrameTime;
void main() {
    gl_Vertex.x += sin(gl_Vertex.x * 0.2 + osg_FrameTime * 1.0) * gl_MultiTexCoord0.y * 0.2;
    gl_Vertex.z += sin(gl_Vertex.y * 0.2 + osg_FrameTime * 1.0) * gl_MultiTexCoord0.y * 0.2;
shader = viz.addShader(vert = vert)
shape.apply(shader)
Old 11-17-2008, 02:29 AM
I updated my driver and now it works as expected. And I now also use the osg global uniforms. Thanx.
Greetings, Joran.
fps performance caused by garbage collection? Mike Konstant Vizard 7 09-03-2012 01:44 PM
Improve performance with large number of onthefly objects? Fox5 Vizard 7 04-28-2008 06:19 PM
5DT Data Glove 5 Ultra Problem bjgold Vizard 1 08-08-2006 05:08 PM
sound problem alaa Vizard 7 09-02-2005 02:13 PM
