Old 03-20-2008, 03:45 AM
Andy Andy is offline
navigation in cave environment
I have a problem by understanding a cave-configuration and navigation respectively. I hope somebody can help me. In my configuration I have one wall (stereo render by two clients), one Polhemus-Fastrak for Head-Tracking and my Keybord for navigation. My Problem is: who can I navigate through my VR-World?
I see a cave-wall like a window by which I see through. Now, when I would like to navigate through my VR-World, in my opinion I have two options: first I can move the Wall an my Viewpoint or second I move the whole world (and my Body\Head is the central point).
Who can I do this with Vizard?
import vizcave
import viztracker
viz.MainWindow.stereo(viz.STEREO_RIGHT)
viz.pushmask(viz.CLIENT1)
viz.popmask()
viz.pushmask(viz.CLIENT2)
viz.MainWindow.stereo(viz.STEREO_LEFT)
viz.popmask()
c0 = -1,2,0
c1 = 1.,2,0
c2 = 1.,0.6,0
c3 = -1,0.6,0
vp = [0, 1.2, -1.6]
vr = [0,0,0]
cave = vizcave.Cave()
#Add a sensor.
tracker = viz.add('fastrak.dls')
FrontWall = vizcave.Wall(upperLeft=c0,upperRight=c1,lowerLeft= c3,lowerRight=c2,name='Front Wall' )
cave.addWall(FrontWall, mask =None, window = viz.MainWindow)
def drawWall():
	viz.startlayer(viz.LINE_STRIP)
	viz.vertex(c0)
	viz.vertex(c1)
	viz.vertex(c2)
	viz.vertex(c3)
	viz.vertex(c0)
	viz.vertexcolor(1,1,0.1)
	viz.startlayer(viz.LINES)
	viz.vertex(c0)
	viz.vertex(vp)
	viz.vertex(c1)
	viz.vertex(vp)
	viz.vertex(c2)
	viz.vertex(vp)
	viz.vertex(c3)
	viz.vertex(vp)
	wall_frame = viz.endlayer()
def UpdateCave():
	# Key's for offsetting my Tracking-data (Position)
	if viz.key.isDown('j'):
		vp[0] -= 1*viz.elapsed()
	if viz.key.isDown('u'):
		vp[0] += 1*viz.elapsed()
	if viz.key.isDown('k'):
		vp[1] -= 1*viz.elapsed()
	if viz.key.isDown('i'):
		vp[1] += 1*viz.elapsed()
	if viz.key.isDown('l'):
		vp[2] -= 0.5*viz.elapsed()
	if viz.key.isDown('o'):
		vp[2] += 0.5*viz.elapsed()
	# Key's for offsetting my Tracking-data (Orientation)
	if viz.key.isDown('f'):
		vr[0] -= 0.5
	if viz.key.isDown('r'):
		vr[0] += 0.5
	if viz.key.isDown('g'):
		vr[1] -= 0.5
	if viz.key.isDown('t'):
		vr[1] += 0.5
	if viz.key.isDown('h'):
		vr[2] -= 0.5
	if viz.key.isDown('z'):
		vr[2] += 0.5
	TP = tracker.getPosition()
	TO = tracker.getEuler()
	NewTO = vizmat.EulerToQuat((vr[0]+TO[1]),(vr[1]+TO[0]),(vr[2]+TO[2])) #swap X-Y and transform in quaternion
	NewTP = [(vp[0]*-1)+TP[0],vp[1]+(TP[1]*-1),vp[2]+(TP[2]*-1)]
	cave.update(pos = NewTP,ori =NewTO)
	viz.MainView.translate(NewTP)
	print "Tracker_P: ", (NewTP)
	print "Tracker_O: ", NewTO
	print "MV_P: ", viz.MainView.getPosition()
	print "MV_O: ", viz.MainView.getEuler()
vizact.ontimer(0,UpdateCave)
viz.add('tut_ground.wrl')
mini = viz.add("mini.osgx")
mini.translate(0,0.7,0)
mini.setScale(0.3, 0.3, 0.3)
mini.add(vizact.spin(0,1,0,15))
drawWall()
Old 03-20-2008, 10:49 PM
The position/rotation values you pass to cave.update() need to be in the same coordinate system as the position values used to specify the wall corners. These are usually the physical coordinates from your tracking system.
The position/rotation of the viewpoint is used for navigation through the virtual world. These values have no relation to the physical tracker units.
When setting up a cave you should use the raw position of your tracker to measure the wall corners. Then at run-time you pass the raw position of your tracker to the cave.update() function. Your keyboard navigation should NOT affect the position values passed to cave.update(), it should only affect the values used to update viz.MainView.
Old 03-25-2008, 02:25 AM
Thank you for your reply, it was very helpful.
I have post my new code is it right so? I only set trackeroffset-values and with the keyboard I move my MainViewpoint. It seems like it works correct…
import vizcave
import viztracker
c0 = -1,2,0
c1 = 1.,2,0
c2 = 1.,0.6,0
c3 = -1,0.6,0
#Add a sensor.
vpT = [0, 1.2, -1.6] # tracker-offset-values
vpM = [0, 1.2, -1.6] # set the Main-ViewPoint in the center of the tracker
viz.MainView.translate(vpM)
def UpdateCave():
	NewTO = vizmat.EulerToQuat(TO[1],TO[0],TO[2]) #swap X-Y and transform in quaternion
	NewTP = [-TP[0]+vpT[0],-TP[1]+vpT[1],-TP[2]+vpT[2]] #invert the tracker-position-data and set offsetvalues
	print "Tracker_P: ", NewTP
	print "Main_VP: ", viz.MainView.getPosition()
	print "Main_VO: ", viz.MainView.getEuler()
def onKeyDown(key):
	#move the main-ViewPoint
	if viz.key.isDown('q'): #left
		vpM[0] -= 1*viz.elapsed()
	if viz.key.isDown('a'): #right
		vpM[0] += 1*viz.elapsed()
	if viz.key.isDown('e'): #forward
		vpM[2] += 1*viz.elapsed()
	if viz.key.isDown('d'): #backward
		vpM[2] -= 1*viz.elapsed()
	if viz.key.isDown('w'): #up
		vpM[1] += 1*viz.elapsed()
	if viz.key.isDown('s'): #down
		vpM[1] -= 1*viz.elapsed()
Old 03-25-2008, 01:36 PM
You still need to apply the tracking data to the main view. In your UpdateCave function you will need add the tracker position and the vpM together to update the viewpoint.
Old 03-28-2008, 02:32 AM
OK fine, now it looks much better…
import vizcave
import viztracker
c0 = -1,2,0
c1 = 1.,2,0
c2 = 1.,0.6,0
c3 = -1,0.6,0
#Add a sensor.
vpT = [0, 1.82, -1.6] # tracker-offset-values
vpM = [0, 0, -1.6] # set the Main-ViewPoint in the center of the tracker
#viz.MainView.translate(vpM)
mini.setScale(1, 1, 1)
def UpdateCave():
	viz.MainView.translate(vpM[0]+NewTP[0],vpM[1]+NewTP[1],vpM[2]+NewTP[2])
TURN_SPEED = 60
def onKeyDown(key):
	#move the ViewPoint
	if viz.key.isDown('w'): #plus
	if viz.key.isDown('s'): #minus
	if viz.key.isDown('e'): #down
	if viz.key.isDown('d'): #up
	#Rotate the ViewPoint
		viz.MainView.rotate(0,1,0,-TURN_SPEED*viz.elapsed(),viz.BODY_ORI,viz.RELATIVE_WORLD)
		viz.MainView.rotate(0,1,0,TURN_SPEED*viz.elapsed(),viz.BODY_ORI,viz.RELATIVE_WORLD)
Now I have a new problem. I want to navigate but I have to use “vpM” and “NewTP” to update the “MainView” function. When I use “viz.MainView.rotate” for ViewPoint-rotation it seems to by ok, but I can not use “viz.MainView.move” because so I do not include the position I get from the Tracker (NewTP).
Do you have an idea?
Problems implementing Vizard in a CAVE with Shutter Glasses shivanangel Vizard 7 05-20-2009 12:47 PM
data glove navigation arielasso Vizard 6 10-24-2007 03:15 PM
environment maps, scenes, and you! vadrian Vizard 1 01-12-2005 05:04 PM
Basic Joystick Navigation Question Plasma Vizard 2 01-29-2004 08:08 PM
Navigation Speed/Too Slow Plasma Vizard 2 01-28-2004 12:07 PM
