Old 11-30-2009, 05:49 AM
Mai Mai is offline
Hand's Collision
I am using the following object to touch balloons (as an example)
hand=viz.add('hand.cfg')
to enable the collision I have used the following code:
handballoon = viz.add('balloon.ive',scale=[0.01,0.01,0.01])
handballoon.collideSphere()
handballoon.disable(viz.DYNAMICS)
handballoon.enable(viz.COLLIDE_NOTIFY)
handballoon_link= viz.link( hand , handballoon )
handballoon_link.preTrans([0.07,-0.07,0])
def onCollideBegin(e):
	if e.obj1 == handballoon:
		if e.obj2==balloon:
			print 'Yes Balloon has been touched :',e.obj2
viz.callback(viz.COLLIDE_BEGIN_EVENT,onCollideBegin)
but it does not work
any help would be appreciated
Old 12-08-2009, 05:35 PM
You need to have the physics engine enabled to detect collisions. Vizard uses the ODE physics engine and it can have problems computing collisions for very small objects. Since your balloon is scaled down to a small size this may be the case if you have enabled physics elsewhere in your script.
Collision detection with specific models just alex Vizard 1 02-06-2009 12:02 PM
Collision Detection and Nearest Point to Probe xabbu Vizard 2 01-06-2009 04:01 AM
Collision with child nodes rubberpimple Vizard 4 09-17-2008 05:27 PM
Collision detection with haptic pen mjabon Vizard 3 01-17-2008 07:35 PM
collision events trigger Eunice Vizard 1 01-03-2006 11:39 AM
