Old 02-03-2009, 03:34 PM
just alex just alex is offline
Collision detection with specific models
Is it possible to have collision detection on only certain objects? In my specific code, I only want collisions between the subject and either the people avatars or the car.
I've also run into an issue on my keydown functions and I don't know why. Since adding the car model, none of my keydowns work anymore. Would it be because I haven't finished writing the car's keydown function, or is there some other problem that I missed?
thanks
-Alex
    import math
    import vizmat
    import vizinfo
    from lookingat import LookingAt
    viz.go(viz.FULLSCREEN)
    #adds the ppt
    PORT_PPT = 1
    ppt = viz.add('vizppt.dls')
    ppt.command(3,"",3,1,3) #scales ppt tracking on xyz axis
    viz.eyeheight(0)
    #collisions on
    viz.collision(viz.ON)
    view.rotate(0,1,0,90)
    #This function is called when a collision occurs
    def mycollision(info):
        print 'Collided'
    #Create a callback for a collision event
    viz.callback(viz.COLLISION_EVENT, mycollision)
    PORT_INTERSENSE = 2
    isense = viz.add('intersense.dls')
    tracker = viz.add('intersense.dls')
    viz.tracker()
    tracker.reset()
    def mykeyboard(key):
        #If the R key is pressed, reset the head orientation
        if key in ['r','R']:
            tracker.reset()
    #Create a keyboard callback
    #Add the street and drop it a little bit to be below the avatars feet.
    street = viz.add('objects/bspcity.bsp')
    street.translate(0,-.2,0)
    males = []
    females = []
    walking = []
    whichturn = 0
    #List the timers.
    WALKING = 0
    DRIVING = 1
    MALEMEETING = 3
    FEMALEMEETING = 4
    THROWINGMAN =7
    HOLDVIEW = 8
    TIMING = 9
    #Add the heads for the males.
    maleheads = ['Male/heads/M-015-2L.vzf','Male/heads/M-056L.vzf', 'Male/heads/M-063L.vzf']
    femaleheads = []
    bodyparts = ['male_legs.cmx','male_torso_LS.cmx','male_shoes.cmx']
    maleclothes = ['Male/clothes/male1.jpg','Male/clothes/male2.jpg','Male/clothes/male3.jpg']
    #Make some avatars.
    for i in range(2):
        male = viz.add('male.cfg')
        male.translate(i,0,0)
        male.visible(0,'male_head.cmx')
        male.face(maleheads[i])
        clothes = viz.add(maleclothes[i])
        for j in bodyparts:
            male.texture(clothes,j)
        males.append(male)
    for i in range(2):
        female = viz.add('female.cfg')
        female.translate(i,0,0)
        females.append(female)
    #Set up paramters for walking guy.
    males[0].translate(0,0,-5)
    males[0].rotate(0,1,0,-90)
    males[0].whichturn = 0
    males[0].set = [[1.5,0,-5],[1.5,0,15],[5,0,15],[-5,0,-5]]
    males[0].end = 4
    walking.append(males[0])
    #Set up paramters for walking girl.
    females[0].translate(1,0,-7)
    females[0].rotate(0,1,0,-90)
    females[0].whichturn = 0
    females[0].set = [[1.5,0,0],[1,0,15],[2,0,15],[-5,0,-5]]
    females[0].end = 4
    walking.append(females[0])
    #Add car.
    car = viz.add('mini.osgx')
    #set car stuff
    car.translate(-1.5,0,8)
    car.rotate(0,1,0,180)
     #Set up for meeting.
     males[1].translate(-9,0,21)
     females[1].translate(2,0,7)
     females[1].state(1)
     malemoves = [2,2,4,4,2,4,4,4,4,4,4,2,2,12]
     femalemoves = [6,5,12,12,1]
     females[1].rotate(0,1,0,-55)
     males[1].rotate(0,1,0,135)
     males[1].state(1)
     #Set up for throwing man.
     males[2].translate(11,0,7)
     males[2].state(1)
     #Set up for timing.
     timebomb = 0
     def onkeydown(key):
         if key == '0':
             viz.starttimer(WALKING, .1, viz.PERPETUAL)
         if key == '9':
             females[1].addAction(6)
             males[1].goto(1.6,0,7.7)
             females[1].spinto(0,1,0,-55)
             females[1].state(12)
             viz.starttimer(MALEMEETING,.1)
             viz.starttimer(FEMALEMEETING,.1)
          if key == '8':
              viz.starttimer(THROWINGMAN,.1)
          if key == '7':
              viz.starttimer(DRIVING,.1)
          if key == 's':
              print 's'
              viz.starttimer(TIMING,1, viz.PERPETUAL)
      def ontimer(num):
          global gravity, timebomb
          if num == DRIVING:
                for
          if num == WALKING:
              for agent in walking:
                  agentposition = agent.get(viz.POSITION)
                  agentgap = vizmat.Distance(agentposition,agent.set[agent.whichturn])
                  if agentgap < .1:
                      agent.whichturn += 1
                      if agent.whichturn == agent.end:
                          agent.whichturn = 0
                  walk = vizact.walkto(agent.set[agent.whichturn][0],agent.set[agent.whichturn][1],agent.set[agent.whichturn][2])
                    agent.addAction(walk)
          if num == MALEMEETING:
              if len(malemoves)>1:
                  animation = malemoves.pop(0)
                  duration = males[1].getduration(animation)
                  males[1].execute(animation)
                  viz.starttimer(MALEMEETING, duration-.15)
                    males[1].state(animation)
            if num == FEMALEMEETING:
                if len(femalemoves)>1:
                    animation = femalemoves.pop(0)
                    duration = females[1].getduration(animation)
                    females[1].execute(animation)
                    viz.starttimer(FEMALEMEETING, duration-.15)
                    females[1].state(animation)
            if num == THROWINGMAN:
                males[2].execute(9)
                males[2].execute(1)
                viz.starttimer(THROWINGMAN, 10)
            if num == HOLDVIEW:
                view.translate(-8.5,1.5,-2)
            if num == TIMING:
                print timebomb
                timebomb += 1
                if timebomb == 1:
                    onkeydown('0')
                elif timebomb == 3:
                    onkeydown('4')
                elif timebomb == 10:
                    onkeydown('2')
                elif timebomb == 20:
                    onkeydown('3')
                elif timebomb == 30:
                    onkeydown('1')
                elif timebomb == 80:
                    viz.quit()
        viz.starttimer(HOLDVIEW,.001, viz.PERPETUAL)
Old 02-06-2009, 11:02 AM
If you have viewpoint collision on you can disable collision with an object by using
<node3D>.disable(viz.INTERSECTION)
It looks like you have two keyboard callbacks that are conflicting.
I think the one that's listed first will not be called
Hand model collision detection. Lotar Vizard 6 04-23-2009 12:18 PM
Collision Detection and Nearest Point to Probe xabbu Vizard 2 01-06-2009 03:01 AM
problem with collision detection paulpars Vizard 6 06-09-2006 06:03 PM
Walking avatars --> collision detection? sjroorda Vizard 3 10-13-2005 04:47 AM
