Old 01-15-2008, 08:15 PM
mjabon mjabon is offline
Collision detection with haptic pen
Hello. I can get collision detection to work on normal objects, but when I try to use it with the haptic pen it does not trigger the event on collision.
I try to just make collide spheres on both a box and on the pen's marker. However, when I move the marker with the pen such that it touches the box I get no collision event. Why is this? How can I detect the collision of the pen with an object? Do I have to just use the haptic pen's touch objects?
Old 01-16-2008, 03:16 PM
For reference I have included the latest version of the script. I am now trying to simply query the touch objects of the haptic pen. However, the balls are not showing up as being touched.
Old 01-17-2008, 05:01 PM
I solved the problem using a work around, but I am still interested in knowing if collision detection can work with the haptic pen. I cannot get it to work at all. If I set collision detection to work on both the pen's marker and an object in the world even when I touch the object I get no collision event triggered.
Old 01-17-2008, 06:35 PM
Can you post the original code you were using that did not work? I am not clear on what you mean by "collision detection". Are you referring to the physics collide events?
collision detection? Colin Vizard 5 05-16-2007 04:52 PM
Collision detection between objects hotspur1 Vizard 4 12-05-2006 11:17 AM
problem with collision detection paulpars Vizard 6 06-09-2006 06:03 PM
Walking avatars --> collision detection? sjroorda Vizard 3 10-13-2005 04:47 AM
Collision Detection for Hierarchies of Objects vjosh Vizard 1 04-15-2005 05:46 PM
