Old 07-01-2009, 06:46 AM
Moh200jo Moh200jo is offline
OSG Export with 3ds Max 2010
Hi Folks,
does any body have an idea how can we use OSG Export with 3ds Max 2010?
any help would be greatlly appreciated!
Old 07-01-2009, 01:21 PM
If you are asking about instructions for exporting a model the Vizard docs have some info about doing that.
http://www.worldviz.com/vizhelp/VizH...#exporting.htm
Old 07-10-2009, 02:06 AM
JvdBosch JvdBosch is offline
OSGExp does not recognize the Max 2010 installation here either (stops while installing)... Can I force the OSGExp to install? I really need to export something to OSG this weekend....
I'l try a restart of the computer, maybe that helps.
Old 07-10-2009, 02:30 AM
Fixed it by renaming registerkey
HKLM "SOFTWARE\Autodesk\3dsMaxDesign\
to
HKLM "SOFTWARE\Autodesk\3dsmax\
And after installing renaming it back. Please fix this in the installer. There are 2 kinds of 3DSMax 2010 available. The design one has another reg-key probably.
Successful Cal3D Export But Texture Problems ezanih Plug-in development 2 01-26-2009 05:28 PM
3ds Max export problem AmyLynn4 Vizard 1 07-28-2008 11:50 AM
Custom Render .EXE export vaestebob Plug-in development 2 05-12-2008 08:55 AM
Export from 3Ds Max to Vizard pattie Vizard 5 08-26-2006 12:20 PM
female skeleton CSF file needed to export to CAF format vmonkey Vizard 1 10-04-2005 11:15 AM
