Old 10-03-2005, 03:20 PM
vmonkey vmonkey is offline
female skeleton CSF file needed to export to CAF format
hello I need to export an animation into a female avatar to be used in vizard. I am currently modifying animations in character studio and exporting them into .CAF files using the CAL3d Plugin. However I do not have female skeleton .CSF file which I need for the export to go through. Where can I obtain such a file?
Old 10-04-2005, 10:15 AM
Are you using the female skeleton that came with Vizard, or your own skeleton? Either way, Cal3D has a MAX plugin to export a character skeleton to a CSF file. It should already be one of the available formats in the export menu.
