Old 06-30-2009, 04:54 AM
jaclyn.bill jaclyn.bill is offline
vertex list
I'm trying to get vizard to draw a set of lines on a certain length along a ground plane which follow a curving path (essentially creating basic road markings).
I really want the lines to follow a set of vertex points set by
x = np.linspace(-np.pi, np.pi, length)
y = x, np.sin(x)
z = some constant
However, I can't seem to get these functions to work in vizard when I create an array:
roadarray = 0.0*np.zeros(201,3)
roadarray[0] = x
roadarray[1] = y
roadarray[2] = z
viz.startlayer(viz.LINE_STRIP)
viz.linewidth(4)
viz.vertexcolor(0, 0.6, 0)
viz.vertex(roadarray[0],roadarray[1],roadarray[2])
lines = viz.endlayer()
Vizard is having problems reading "roadarray = 0.0*np.zeros(201,3)" (saying "TypeError: data type not understood") even though I can get this to create an array in python.
I'm sure this is a small error on my part, but if any one can point me in the right direction I would be grateful.
Many thanks.
J
Old 06-30-2009, 10:27 AM
It looks like you are using the numpy.zeroes function incorrectly. I believe it should be:
roadarray = 0.0*np.zeros((201,3)) #Need the inner parentheses
Old 07-01-2009, 08:17 AM
I'm sorry but I'm still having problems with this and can't understand why it won't read my array. It is giving the error "TypeError: x must be a float" if I try to convert x to a float (which I thought it already was) I get the error "TypeError: only length-1 arrays can be converted to Python scalars
length = 200
viz.vertexcolor(1,1,1)
viz.linewidth(5)
roadarray = 0.0*np.zeros((length,3))
z = np.sin(x)
roadarray[:length,0]= x
roadarray[:length,1]= 0
roadarray[:length,2]= z
viz.vertex(roadarray[:length,0],roadarray[:length,1],roadarray[:length,2])
I'd be grateful for any advice on this, I'm not a python expert!
Best, j
Vertex shader performance problem Joran Vizard 2 11-17-2008 02:29 AM
onkeydown list of values Cheff Vizard 2 07-02-2008 03:00 AM
How to get the position of a vertex Jerry Vizard 1 10-04-2006 12:28 PM
get vertex with on the fly object enkeli Vizard 9 05-25-2006 09:27 PM
GLSL / vertex shaders oodini Vizard 1 11-23-2005 11:24 AM
