Old 07-01-2008, 01:29 AM
Cheff Cheff is offline
Question onkeydown list of values
i'm quit a rookie in the world of Vizard and i have a problem with making a list of values by keyboard action.
I have a list of values (60, 69, 52, 9, 55, 58, 10, 18, 56) and I want vizard to run throug the list from the beginning to the end , each time you hit the spacebar I want the script to give the next value. Once the last value is reached, I want it to jump back to the beginning and repeat.
I've tried something like this:
def onkeydown (key):
	if key == ' ':
		print vizact.choice( [60, 69, 52, 9, 55, 58, 10, 18, 56], viz.LOOP )
but it doesn't quite work.
Can anybody help me with this problem?
Thanx
Old 07-01-2008, 10:03 AM
Try the following code, it should do what you ant:
numberCycle = viz.cycle([60, 69, 52, 9, 55, 58, 10, 18, 56])
def PrintNumber():
	print numberCycle.next()
vizact.onkeydown(' ',PrintNumber)
Old 07-02-2008, 02:00 AM
yes it works!
thank you
Incoming floating point values Rachel Vizard 1 02-12-2008 03:09 PM
