You could calculate the velocity from one frame to the next using the following:
lastPos = [0,0,0] def calculateVelocity(): global lastPos pos = device.getPosition() distance = vizmat.Distance(lastPos,pos) velocity = distance/viz.getFrameElapsed() lastPos = pos vizact.onupdate(0,calculateVelocity) |
| Tags |
| omni, velocity |
| Information associated with a model | roobert | Vizard | 7 | 08-01-2014 09:34 AM |
| MainView velocity depending on joystick deflection | 4711 | Vizard | 3 | 01-17-2014 12:50 PM |
| velocity shader | subbu | Vizard | 0 | 11-24-2013 06:56 AM |
| how to remove velocity when mouse is disabled? | jvacare1 | Vizard | 2 | 02-18-2010 10:25 AM |
| How Can I use two SensAble Omni at the same time | junghungchien | Vizard | 0 | 09-03-2009 07:04 AM |
