Old 01-16-2014, 07:06 AM
4711 4711 is offline
MainView velocity depending on joystick deflection
Hi all,
how can I move the viz.MainView with a certain velocity (in virtual meters per second) independent of the controlling device (i.e. joystick, gamepad, ...) and the machine on which I'm running the script (i.e., old laptop, new desktop, ...)?
Currently I'm using:
# add joystick
joy = vizjoy.add()
# define joystick parameters
thresh = 0.2
stepWidth = 0.01
# timer function, called every 0.05 seconds
def updateJoystick(self):
	# get joystick position
	joy_x, joy_y, joy_z = joy.getPosition()
	# move viewpoint forward/backward based on y-axis value
	if abs(joy_y) > thresh:
		viz.MainView.move([0, 0, -joy_y*stepWidth], viz.VIEW_ORI)
	# move viewpoint left/right based on x-axis value
	if abs(joy_x) > thresh:
		viz.MainView.move([joy_x*stepWidth, 0, 0], viz.VIEW_ORI)
# schedule timer
vizact.ontimer(0.05, updateJoystick)
This works nice in principle, but the actual speed, that is, the distance moved within the 0.05 seconds, seems to depend on both the input device (i.e.., one joystick seems to generate faster movement than another), and the machine (i.e., on faster computers the distance is larger than on older machines). That means I have to determine the stepWidth manually for each machine and device, based on trial and error.
So, is there a way around this? Is it possible to set the MainView's velocity in m/s, depending on the joystick's current deflection (via joy.getPosition())?
Any help is appreciated!
Old 01-16-2014, 11:09 AM
Try setting the timer expiration time to 0 so it expires every frame. Then use viz.getFrameElapsed to get the elapsed time since the previous frame and multiply that against the speed in m/s and joystick position:
viz.MainView.move([0, 0, -joy_y * SPEED * viz.getFrameElapsed()])
Old 01-17-2014, 08:57 AM
Thanks a lot, Jeff, that was exactly what I was looking for!
And a follow-up question: Any suggestions how to achieve the same for rotating (not translating) the viewpoint, depending on the joystick's X deflection? Probably using viewpoint.moveTo()?
Old 01-17-2014, 12:50 PM
You could use viewpoint.setEuler and update the yaw value every frame:
viz.MainView.setEuler([ joy_x * TURN_SPEED * viz.getFrameElapsed(), 0, 0 ], viz.REL_PARENT)
joystick, velocity
Mainview can't go back to original point jacky Vizard 1 06-04-2013 04:22 AM
joystick position nmohandes Vizard 2 01-16-2012 10:03 AM
how to remove velocity when mouse is disabled? jvacare1 Vizard 2 02-18-2010 10:25 AM
Joystick Navigation Vinicius Lima Vizard 7 10-23-2007 10:42 AM
Facetracking and Immersion Joystick Vygreif Vizard 1 01-25-2006 10:56 AM
