Old 02-26-2021, 05:15 AM
Roy Roy is offline
Install Psychopy3 into Vizard7
Does anyone know how to install and use psychopy3 in vizard7?
When I tried to install it from vizard's package manager, I got error as below,
error: command 'C:\\Program Files (x86)\\Microsoft Visual Studio\\2019\\BuildTools\\VC\\Tools\\MSVC\\14.28.2 9333\\bin\\HostX86\\x64\\cl.exe' failed with exit status 2
ERROR: Failed building wheel for cryptography
Running setup.py clean for cryptography
Failed to build cryptography
ERROR: Could not build wheels for cryptography which use PEP 517 and cannot be installed directly.
This error is involved in cryptography, how to fix?
Old 08-25-2021, 10:01 AM
mspusch mspusch is offline
Hi Roy,
I believe this was addressed in the WorldViz closed support forum, and you got the answers you needed?
Please let me know if this is still an open issue at this point,
Matthias
Old 10-04-2021, 12:53 AM
Roy Roy is offline
Hi Matthias,
This issue should be still opened because there have been no answers.
Old 10-04-2021, 06:48 AM
Hi Roy, thanks for the note back, we'll have a look at it and get back to you.
Matthias
Old 10-04-2021, 04:26 PM
We tested the latest version of Vizard (7.2.1) and psychopy 2020.2.10 works, but 2021.2.3 did not. It might be worth looking into what changed on the psychopy side.
To install the 2020.2.10 version you can go to the Package Manager, CMD tab and type in
install psychopy==2020.2.10
Best,
Sado
Old 10-05-2021, 02:19 PM
AustinNorth AustinNorth is offline
Registered User
Hi I had the same problem, not solved until now
Old 02-17-2022, 11:18 AM
It seems you can install the latest Psychopy now with Vizard 7.3 that was just released
vizard7
Offline GDAL install saket Vizard 5 05-15-2019 04:05 AM
How to install pySerial Suze Vizard 2 08-14-2017 04:42 AM
Vizard5 Failed to Install zaylin Vizard 2 01-05-2015 06:17 PM
Can I install different versions in the same computer? Melody Vizard 2 10-11-2014 12:25 PM
New Install Crashes Nevyle Vizard 6 06-28-2010 11:21 AM
