Old 06-26-2010, 01:28 AM
Nevyle Nevyle is offline
Exclamation New Install Crashes
Hello
Im new to this program. downloaded the evaluation (3.0), and its runs, but only the 'simple' tutorials work. the others crash.
(windows 7 btw)
Also, when doing the 1st tutorial, I can drag room.wrl into the workbench, but it crashes as soon as I supply a name.
Sofar It seems I cant really use any of this....
Any suggestions ?
Old 06-26-2010, 01:42 AM
btw
I have an ATI radeon X1950 (which is not that old)
(but since it is just a crash, without info, i have no idea if its related to my graphics card)
Old 06-28-2010, 12:33 AM
Anyone ?? plz ??
I need to build a thesis project using this software, so It would be nice to get it to work...
Again, I open de program, open de tutorial, press run, it does something:
** Loading tutorial.py
Loading File: vcc_male.cfg
Loading File: room.wrl
Loading File: light.WRL
** Load Time: 1.95 seconds
then it crashes.....
are there some settings I need to set maybe ??
thanx anyways.
regards
Nev
Old 06-28-2010, 01:27 AM
znchb znchb is offline
Is your Win7 runs the 64-bit or 32-bit operation system?
I don't know whether there is any conflict with 64-bit system.
But Mine is 32-bit, install the Vizard 3.0 and run program, that's it.
Old 06-28-2010, 02:33 AM
just ordinary 32bit.
just like you...
thanx, that at least lets me know its possible
Old 06-28-2010, 10:35 AM
Vizard should run fine on both 32-bit and 64-bit system. Have downloaded and installed the correct drivers for you graphics card?
Old 06-28-2010, 12:21 PM
Yes I have.
I have solved the problem.
It is because of my video card setting(s) ( ATI catalyst )
(but not bad drivers or something, apparantly something is not supported by Vizard)
When dropping all to lowest of the low setting, it works.
Ill try to figure out which option is the nasty ....
and, if anyone is interested (??) post that.
thanx for the replies
Bluetooth speaker crashes Vizard? GiudiceLab Vizard 2 06-09-2009 05:56 PM
just downloaded Vizard Lite - crashes upon startup... bernie Vizard 6 11-23-2008 10:56 AM
winvix.exe crashes mjabon Vizard 1 08-27-2007 10:15 AM
Help with Vizard crashes... vanier Vizard 1 01-12-2006 03:08 PM
Vizard Crashes: causes are hard to determine, possible problem with the viz code vr_boyko Vizard 1 01-07-2005 11:52 AM
