Old 05-08-2018, 01:42 PM
simrus simrus is offline
Moveable clipping box
Hi
I'd like to create a clipping box like this
http://forum.worldviz.com/showthread...light=clipping
but where I can move (translate and rotate) the clipping box.
I'm struggling to find a solution. Can anyone help?
simon
Old 05-08-2018, 06:21 PM
Here's an example. Use the left and right arrow keys to move the box:
Move the clip box left and right
with the arrow keys
import vizshape
import vizinfo
vizinfo.InfoPanel()
class MovingClipBox():
	def __init__(self,node,center,size):
		self.node = node
		self.x,self.y,self.z = center
		self.sx,self.sy,self.sz = [ v / 2.0 for v in size ]
		self.applyClipBox()
		self.box = vizshape.addBox(size=size,pos=center,color=viz.RED,lighting=False)
		self.box.polyMode(viz.POLY_WIRE)
	def applyClipBox(self):
		self.node.clipPlane([1,0,0,self.x-self.sx],num=0)
		self.node.clipPlane([-1,0,0,-self.x-self.sx],num=1)
		self.node.clipPlane([0,1,0,self.y-self.sy],num=2)
		self.node.clipPlane([0,-1,0,-self.y-self.sy],num=3)
		self.node.clipPlane([0,0,1,self.z-self.sz],num=4)
		self.node.clipPlane([0,0,-1,-self.z-self.sz],num=5)
	def getBoxCenter(self):
		return [self.x,self.y,self.z]
	def setBoxCenter(self,center):
		self.applyClipBox()
		self.box.setPosition(center)
viz.clearcolor(viz.GRAY)
vizshape.addGrid(color=[0.2]*3)
model = viz.add('logo.osgb')
expand = vizact.sizeTo([3,3,3],speed=0.5)
shrink = vizact.sizeTo([1,1,1],speed=0.5)
model.runAction(vizact.sequence(expand,shrink,viz.FOREVER))
model.runAction(vizact.spin(0,1,0,20,viz.FOREVER),pool=1)
BOX_CENTER = [0,2,0]
BOX_SIZE = [2,2,2]
movingClipBox = MovingClipBox(model,center=BOX_CENTER,size=BOX_SIZE)
import vizcam
vizcam.PivotNavigate(center = BOX_CENTER, distance = 10.0)
def updateClipBox():
	x_change = 0
	if viz.key.isDown(viz.KEY_LEFT):
		x_change -= 0.01
	elif viz.key.isDown(viz.KEY_RIGHT):
		x_change += 0.01
	if x_change != 0:
		center = movingClipBox.getBoxCenter()
		center[0] += x_change
		movingClipBox.setBoxCenter(center)
vizact.onupdate(0,updateClipBox)
box, clipping, move, plane, rotate
Create a clipping box pswaney Vizard 1 03-01-2013 01:19 PM
Clipping Plane envisC Vizard 8 10-23-2012 01:36 PM
Can I make a moving clipping plane? Salvar Vizard 3 04-18-2012 01:32 PM
Near and far clipping on infinite terrain vijaykiran Vizard 2 01-21-2011 05:59 AM
Does the automatic clipping plane calculation work? Joran Vizard 4 07-10-2009 11:35 AM
