Old 08-09-2017, 10:31 AM
krimble krimble is offline
maintaining transparency in a model while fading in
Dear Worldviz,
I'm having troubles with transparency in a model while fading in.
When not using model.alpha or vizact.fadein the model works fine and the glass in the model is transparent.
I would like to fadein in the model, maintaining the transparency of the glass.
How do I do this?
Thank you!
Best, Jeroen
Max Plank Institute Nijmegen
Old 08-09-2017, 10:23 PM
Are you able to attach or upload an example that shows the issue?
Old 08-10-2017, 06:02 AM
Hi Jeff, thank you. I just uploaded two files. ref: 1767341
Old 08-17-2017, 07:10 AM
Hi Jeff,
is there any news on the transparant material turning white when fading the object in?
Thank you.
Best,
Jeroen Derks
Access the vertices of a model pankaj bansal Vizard 1 03-29-2013 08:02 PM
Accesing different parts of model pankaj bansal Vizard 1 12-30-2012 11:10 PM
3ds Exported .IVE Model mirrors movement of Mainview Felix Vizard 9 05-18-2012 10:17 AM
Change model alpha and memory leak hosier Vizard 2 06-25-2009 11:55 AM
