Old 03-26-2013, 04:33 AM
pankaj bansal pankaj bansal is offline
Access the vertices of a model
Hey
I have a problem. I need to calculate the convex hull of an 3D model loaded in vizard. I have the code to do that but for that I need all the vertices of the model ie. their coordinates in a array. I need to access all the vertices of the object but I am not able to find any method to do that. Can you please tell me how can I access all the vertices of the model.
PS. the model is a complex model and is not a on-the-fly object. Its a .ive or 3ds max file. so plz tell me how can I access the vertices.
Regards
Pankaj Bansal
Old 03-29-2013, 08:02 PM
There is currently no built-in way to access the vertices, but you can save the model to the STL format, which is a simple text format that contains all the vertices. Here is some sample code allows you to iterate over the vertices:
model = viz.add('logo.ive')
def getVertices(node):
	"""Iterate over vertices"""
	node.save('temp.stl')
	vertices = []
	with open('temp.stl','r') as f:
		for line in f:
			s = line.split()
			if s and s[0] == 'vertex':
				yield float(s[1]), float(s[2]), -float(s[3])
verts = list(getVertices(model))
access vertices
Accesing different parts of model pankaj bansal Vizard 1 12-30-2012 11:10 PM
3ds Exported .IVE Model mirrors movement of Mainview Felix Vizard 9 05-18-2012 10:17 AM
Change model alpha and memory leak hosier Vizard 2 06-25-2009 11:55 AM
Importing a 3d human model and getting it to interact. yak Vizard 3 06-01-2009 03:19 PM
Model sizes Pastscapian Vizard 15 10-07-2006 03:48 PM
