Old 05-12-2017, 09:43 AM
engelskri3ger engelskri3ger is offline
Using 2 slider joints to move on a plane
Hey there,
I'm working on a project where I need to use a portalcrane where the mounted object is moved by grabbing it with the vizconnect grabber and the parts of the crane should move too. I want to use the built-in physics engine, so i tried to use multiple joints to connect the crane parts, but I didn't figure out yet, how I could use 2 slider joints to get the crane moving in the room.
Is there a way to do this? This is an example code I use for testing purposes:
# Options
CYCLES_PER_SEC = 0.05  # Frames
viz.setMultiSample(4)  # Multisampling
viz.setOption('viz.max_frame_rate', 60)  # Avoid flickering
viz.vsync(viz.OFF)  # V-Sync
viz.collision(viz.ON)  # Viewport Collision
viz.phys.enable()  # Physics Simulation
viz.setOption('viz.model.cache', viz.CACHE_CLONE)
vizconnect.go(r'../vizconnect_files/keyboard.py') # Standard Vizconnect Keyboard Setting
# Loading of Objects
grabber = vizconnect.getRawTool('grabber')
position = [5.0, 0, 0]
room = viz.add('lab.osgb')  # Room is loaded
room.collideMesh()  # Room gets Collision
box = vizshape.addBox(size=[12.8, 0.2, 0.2], pos=[0, 5.5, position[2]])
box.collideBox()
box_joint = viz.phys.addSliderJoint(box, None, pos=[0, 5.5, position[2]], axis0=(0, 0, 1))
box_joint.setAxisLimit(0, -6, 6)  # Limit sliding distance
box_joint.setAxisBounce(0, 0)  # Change end bounce properties
rope = vizshape.addBox(size=[0.075, 3, 0.075], pos=[position[0], 3.9, position[2]])
rope.collideBox()
rope_joint = viz.phys.addSliderJoint(rope, None, pos=[position[0], 3.9, position[2]], axis0=(1, 0, 0))
rope_joint.setAxisLimit(0, -12.8 / 2 - position[0],12.8 / 2 - position[0]) # Limit sliding distance
rope_joint.setAxisBounce(0, 0)  # Change end bounce properties
# rope_box_joint = viz.phys.addFixedJoint(box, rope)
grabber.addItems([rope])
Old 05-15-2017, 06:59 AM
I'll check with a developer but I'm not sure if this is possible using the physics engine. It may require IK code that moves the joints based on the object's position.
Old 05-19-2017, 06:11 AM
Is there some way you can show how you expect the objects to move together, maybe a diagram or picture.
Slider Assistance new_horizon Vizard 3 05-16-2012 07:32 AM
Tiling a texture on a plane FreakyT Vizard 2 04-27-2011 05:34 PM
adding more than 1 action for avatar animation slider control yak Vizard 0 07-21-2009 11:22 AM
Vizmenu slider bug? Gladsomebeast Vizard 2 10-22-2008 08:05 PM
I need help with the Far Clip Plane... k_iwan Vizard 3 03-13-2007 04:54 AM
