Old 04-27-2011, 01:43 AM
FreakyT FreakyT is offline
Question Tiling a texture on a plane
This seems like it should be easy, but it's not working for me, so perhaps someone could figure it out.
Anyway, I'm trying to create a large plane with a "grass" looking texture on it. (Pretty simple!) The plane is a VRML file (attached) containing an IndexedFaceSet. (I found that Vizard's physics engine didn't work right on objects with small numbers of triangles, so I had to tesselate the "plane" a lot)
However, I can't get the plane to get a texture! I figure maybe it's getting one but really stretched out, however I can't seem to get it to tile a scaled down version of the texture, either. Any ideas on how to do this?
Old 04-27-2011, 12:45 PM
It maybe your model does not have texture coordinates. Was it exported without a texture?
Old 04-27-2011, 05:34 PM
Also, make sure the wrap mode on the texture object is set to viz.REPEAT.
texture = viz.addTexture('grass.jpg',wrap=viz.REPEAT)
plane, texture, vrml
Texture applid on a plane gets inverted in one of its the sides Renato Lima Vizard 1 03-14-2011 06:16 PM
Texture tiling ChrisB Vizard 2 08-13-2004 11:49 AM
