Old 03-23-2017, 10:37 AM
Lenticularis Lenticularis is offline
Question How to call Oculus Remote
Hi
I want to add an action by pressing a button on the Oculus Remote.
But how do I call the remote? And how do I associate a button press of the remote with an action?
The reference page about the Oculus HMD wasn't very helpful.
Old 03-23-2017, 11:24 AM
To further clarify:
The ultimate goal is to use the remote as a replacement for all keyboard and mouse input. But for a start, I want to associate the press of the enter key on the remote with the left mouse button, in order to select options with the remote instead of the mouse.
Old 03-23-2017, 11:57 PM
Are you referring to selecting options within a GUI object? If so, take a look at the GUI canvas page and canvasExample.py script (File > Quick Open: type canvasExample). Using the GUI canvas, set the cursor style to viz.CANVAS_MOUSE_VIRTUAL and apply updates to the cursor based on oculus remote signals. The example script shows how to manually update the cursor position and send mouse button events using keypresses in the ManualCursorPositionTask and ManualCursorButtonTask functions. In your case you would change the keypress checks to button checks.
Old 04-11-2017, 12:57 PM
Hi again
Thanks for your answer.
I'm referring to the canvas example script, yes.
I tried to change the keypresses to button checks but I can't get it working. Is there a mistake somewhere in my script?
I'd be really glad for any kind of advice.
import vizcam
import vizdlg
import vizinfo
import viztask
canvas = viz.addGUICanvas()
canvas.setRenderWorldOverlay([800,600],50,3)
canvas.setPosition([0,0,0])
viz.mouse.setTrap(True)
viz.mouse.setVisible(False)
canvas.setMouseStyle(viz.CANVAS_MOUSE_VIRTUAL)
# Apply settings
viz.MainWindow.setDefaultGUICanvas(canvas)
import oculus
hmd = oculus.Rift()
remoteEnter = viz.addButton(oculus.BUTTON_REMOTE_ENTER)
remoteUp = viz.addButton(oculus.BUTTON_REMOTE_UP)
remoteDown = viz.addButton(oculus.BUTTON_REMOTE_DOWN)
remoteLeft = viz.addButton(oculus.BUTTON_REMOTE_LEFT)
remoteRight = viz.addButton(oculus.BUTTON_REMOTE_RIGHT)
# Load environment models
worlds = [ viz.addChild('maze.osgb'), viz.addChild('gallery.osgb'), viz.addChild('dojo.osgb') ]
for i, model in enumerate(worlds):
	model.visible(i == 0)
controlPanel = vizinfo.InfoPanel(text='Navigate with WASD', title='Canvas Example')
controlPanel.addSeparator()
manual_cursor = controlPanel.addLabelItem('Manual Cursor',viz.addCheckbox())
def ManualCursorPositionTask():
	"""Use arrow keys to manually move canvas cursor"""
	while True:
		pos = canvas.getCursorPosition(viz.CANVAS_CURSOR_PIXELS)
		inc = 250.0 * viz.getFrameElapsed()
#		if viz.key.isDown(viz.KEY_UP):
#			pos[1] += inc
#		if viz.key.isDown(viz.KEY_LEFT):
#			pos[0] -= inc
#		if viz.key.isDown(viz.KEY_DOWN):
#			pos[1] -= inc
#		if viz.key.isDown(viz.KEY_RIGHT):
#			pos[0] += inc
#		canvas.setCursorPosition(pos, viz.CANVAS_CURSOR_PIXELS)
		if remoteUp.get() == viz.DOWN:
			pos[1] += inc
		if remoteLeft.get() == viz.DOWN:
			pos[0] -= inc
		if remoteDown.get() == viz.DOWN:
			pos[1] -= inc
		if remoteRight.get() == viz.DOWN:
			pos[0] += inc
		yield viztask.waitFrame(1)
def ManualCursorButtonTask():
	"""Use spacebar to manually simulate mouse press/release on canvas"""
	while True:
#		yield viztask.waitKeyDown(' ', priority=viz.PRIORITY_GUI_HANDLER-1)
#		canvas.sendMouseButtonEvent(viz.MOUSEBUTTON_LEFT, viz.DOWN)
#		yield viztask.waitKeyUp(' ', priority=viz.PRIORITY_GUI_HANDLER-1)
#		canvas.sendMouseButtonEvent(viz.MOUSEBUTTON_LEFT, viz.UP)
		yield viztask.waitButtonDown(remoteEnter, priority=viz.PRIORITY_GUI_HANDLER-1)
		yield viztask.waitButtonUp(remoteEnter, priority=viz.PRIORITY_GUI_HANDLER-1)
def ToggleManualCursorTask():
	"""Handle toggling of manual cursor mode"""
	notice_panel = vizinfo.InfoPanel('Arrow keys control cursor.\nSpacebar simulates button press.', title='Manual Cursor Enabled', align=viz.ALIGN_RIGHT_TOP, key=None, icon=False)
	notice_panel.visible(False)
	while True:
		yield viztask.waitButtonDown(manual_cursor)
		# Enable manual cursor control
		UpdateMouseStyle()
		pos_task = viztask.schedule(ManualCursorPositionTask())
		button_task = viztask.schedule(ManualCursorButtonTask())
		notice_panel.visible(True)
		yield viztask.waitButtonUp(manual_cursor)
		# Disable manual cursor control
		UpdateMouseStyle()
		pos_task.remove()
		button_task.remove()
viztask.schedule(ToggleManualCursorTask())
Old 04-12-2017, 03:38 AM
First get a handle to the remote controller:
hmd = oculus.Rift()
remote = hmd.getRemoteController()
Then in the function that updates the cursor check the remote controller button states:
if remote.isButtonDown(oculus.BUTTON_REMOTE_UP):
	pos[1] += inc
if remote.isButtonDown(oculus.BUTTON_REMOTE_LEFT):
	pos[0] -= inc
if remote.isButtonDown(oculus.BUTTON_REMOTE_DOWN):
	pos[1] -= inc
if remote.isButtonDown(oculus.BUTTON_REMOTE_RIGHT):
	pos[0] += inc
Does this work for you?
Old 04-13-2017, 12:43 PM
That's exactly what I was looking for, thanks!
But how would you change the ManualCursorButtonTask function?
	while True:
Old 04-13-2017, 11:24 PM
Try using the viztask.waitSensorDown and viztask.waitSensorUp commands:
	while True:
		yield viztask.waitSensorDown(remote, oculus.BUTTON_REMOTE_ENTER, priority=viz.PRIORITY_GUI_HANDLER-1)
		yield viztask.waitSensorUp(remote, oculus.BUTTON_REMOTE_ENTER, priority=viz.PRIORITY_GUI_HANDLER-1)
Old 04-20-2017, 12:32 PM
Thanks very much!
action, button, oculus, oculus remote
Oculus Rift + Vizard help required sukhpreet Vizard 1 01-03-2017 11:52 AM
Xbox controller and Oculus DK2 prilpi Vizard 17 03-28-2016 06:00 AM
3D text oculus for right to left languages bbb Vizard 2 01-16-2016 08:02 AM
Multiple post-process effects with oculus rift lklab Vizard 2 03-13-2015 02:48 PM
