Old 01-22-2015, 04:08 PM
Oculus runtime disrupts clustering to mirror DK2 display
Hello! I can't seem to get my DK2 display to mirror correctly on a second monitor, and it appears to be because of the Oculus Runtime.
I am following your suggestion to use clustering to create two independent views of the scene, one window inside the Oculus Rift DK2 that uses the oculus module, and 1 on my desktop monitor that does not.
Although clustering does appear to create two windows, nothing is being rendered to the window that is not displayed on the DK2 unless I disable the oculus module.
Strangely enough, this is true when the client is on the local machine, or when it's on another machine on the LAN.
Example code pasted below. Note that you may have to change variables expMon to the ID of the desktop monitor and hmdMon to the ID of the Oculus Rift DK2.
Note that it will work if you comment out lines 40-50 (the parts which enable the Oculus module).
# Load environment
piazza = viz.add('piazza.osgb')
viz.add('piazza_animations.osgb')
# Swap out sky with animated sky dome
piazza.getChild('pz_skydome').remove()
day = viz.add('sky_day.osgb')
day.renderToBackground()
expMon = 2
hmdMon = 1
with viz.cluster.MaskedContext(viz.ALLCLIENTS):
	viz.window.setFullscreenMonitor(expMon)
	#viz.setMultiSample(8)
	#viz.vsync
	viz.window.setFullscreen(True)
	#viz.setOption('viz.glFinish',1)
	text1 = viz.add(viz.TEXT3D,'EXP')
	text1.alignment(viz.ALIGN_RIGHT_BOTTOM)
	text1.setPosition([0.5,0.5,0])
with viz.cluster.MaskedContext(viz.MASTER):
# The oculus is master
	import oculus
	viz.window.setFullscreenMonitor(hmdMon)
	viz.vsync
	# Setup Oculus Rift HMD
	hmd = oculus.Rift()
	if not hmd.getSensor():
		sys.exit('Oculus Rift not detected')
	# Go fullscreen if HMD is in desktop display mode
	if hmd.getSensor().getDisplayMode() == oculus.DISPLAY_DESKTOP:
	text1 = viz.add(viz.TEXT3D,'HMD',parent=viz.SCREEN)
Old 01-23-2015, 08:00 AM
oh, and to be clear:
Disabling the Oculus Runtime is not a satisfactory solution. It allows one to render to the desktop mirror of the in-helmet view. However, the in-helmet view no longer benefits from the necessary computations required for accurate display inside the Oculus Rift.
So, with the runtime on, the in-helmet view is good, but the desktop mirror is not.
With the runtime off, the desktop mirror is good, but the in helmet view is not.
- gD
dk2, experimenter display, mirror display, oculus, oculus runtime
Duplicate HMD display on primary monitor, with eyetracking info performlabrit Vizard 3 09-19-2014 11:44 AM
