Old 01-25-2017, 12:58 PM
Canucks Canucks is offline
coordinates
I have a question regarding coordinates. When you run a scene let's say I ran lab.wrl that's in the resource. When you run the program , are we at position 0,0,0? Where about are we located? What about when we connect to Optotrak? How do we know the coordinates of our starting point?
Old 01-25-2017, 04:10 PM
If you're using the default mouse navigation to control the viewpoint, the starting position is [0,1.8,0]. If the viewpoint is controlled by tracking data and there are no other offsets applied, the starting location should be the position returned by the tracking device.
Old 01-25-2017, 04:15 PM
Thank you very much for your reply. How can we return the starting position if we are using Optotrak?
coordinate system, optotrak, scene
Texture Coordinates in a Cube Map mshukun Vizard 2 05-10-2013 12:31 PM
360 panorama image cube using as darts target and record the xy coordinates mshukun Vizard 2 03-14-2013 06:17 AM
How do coordinates in IS900 thransform into coordinates in vizard's world jacky Vizard 1 08-11-2011 10:44 AM
child-objects in VRML-file all have the same coordinates Sven Vizard 4 06-09-2010 02:07 AM
viz.vertex coordinates lilio Vizard 6 05-16-2009 04:36 PM
