Old 05-13-2009, 10:43 AM
lilio lilio is offline
viz.vertex coordinates
I want to create a vertex at the mouseclick position, but I don't know how to do it.
If I create two vertex points:
viz.startlayer(viz.POINTS)
viz.pointsize(10)
viz.vertexcolor(viz.RED)
viz.vertex(0,0,10)
viz.vertex(1,1,10)
line = viz.endlayer()
And afterthat I click with my mouse at these points and look at my output window:
print viz.mouse.getPosition()
Then I had to recognize, that there are absolutly different values.
The vertex are at [0,0,10] and [1,1,10] and my mouseposition shows [0.6,0.3] and [0.5,0.2]!
Are the vertex coordinates world coordinates? Or what means 0,0,10? And what are the mouseposition coordinates?
What's the reason for this difference. I want to create vertex at the mouseclick position.
Can anybody help me - please.
Old 05-14-2009, 03:31 AM
If I create the vertex with this command:
point = viz.endlayer(viz.WORLD)
then the vertex will be placed at another position like the mouse is.
But if I use
point = viz.endlayer(viz.SCREEN)
then the vertex will be placed at the mouseclick position.
But I don't want to place the vertex at the screen. It should be placed in the world at the mouseposition and at 0 on the z-axis.
I hope somebody understand my problem.
I only want to create a vertex in the world (not at the screen), but exactly at the mouseposition.
Is this possible?
Old 05-14-2009, 10:56 AM
Use the "screentoworld" method to get a direction vector. Then use vizmat.MoveAlongVector to find a place in space.
Old 05-15-2009, 04:25 AM
Chrissy2009 Chrissy2009 is offline
Hey Gladsomebeast,
I've got the same problem. I want to create points in the world, not on the screen.
But I don't understand your answer. Could you write down the code, please?
THANKS!
Old 05-15-2009, 11:58 AM
Looks like we don't need MoveAlongVector. Got this code from viztracker.py:
line = viz.screentoworld(viz.Mouse.getPosition())
line.length = desiredMetersFromView
print line.end
Old 05-16-2009, 09:09 AM
Oh great, thanks a lot!!
Old 05-16-2009, 04:36 PM
Helping make me happy.
Getting object position in screen coordinates v-Salik Vizard 1 10-19-2007 03:41 PM
getPosition coordinates AlyssaK Vizard 4 01-18-2007 04:19 PM
Locating the Coordinates of Vertices for on the fly objects shivanangel Vizard 4 10-30-2006 08:28 PM
Translate HEAD_POS to absolute coordinates? vrhelp2004 Vizard 1 05-18-2004 04:53 PM
