Old 11-03-2016, 10:25 AM
mihirradia mihirradia is offline
Abnormal Behavior
I'm using a Zspace 200 and when I'm trying to grab an object in the virtual environment there is an abnormal behavior. I think it'll be better understood if looked at the video that is attached in this thread. I'm trying to figure out the reason and still couldn't find it. I am hoping, if you could give me some suggestion what is causing this abnormal behavior? and where can I look at to solve this issue?
Please extract the file before watching the video.
Thanks in advance.
Old 11-04-2016, 01:16 PM
Can you post the code you're running for this video?
Old 11-04-2016, 02:09 PM
Please find the attached code
Old 11-04-2016, 02:24 PM
If you want to run the file and execute it. I think the google drive has the supporting documents that will help you to execute the main file.
https://drive.google.com/open?id=0B6...VNiQ3NSeE95MGs
Old 11-04-2016, 03:47 PM
Sorry, I took a look at the code but don't have any suggestions. It's seems there is additional functionality built into your program beyond the simple grabbing of objects. Debugging custom code is beyond the scope of what we can help with on the forum.
Weird behavior of on-the-fly objects tokola Vizard 2 07-10-2015 10:05 AM
Unexpected Avatar lookAt() behavior when using yield statements chris2307 Vizard 2 12-17-2013 02:58 AM
Realistic gaze behavior of CCHD characters Frank Verberne Vizard 4 11-06-2013 12:07 AM
strange collision behavior after export from Sketchup? fivel_lab Vizard 2 02-09-2012 03:43 PM
