Old 08-25-2016, 09:42 AM
Eugene Eugene is offline
Disable Clicking of Button
I've created a system status panel using buttons and would like to prevent the subject from accidentally clicking on the buttons. Currently, when I click on the 'Normal' button, it becomes unshaded.
May I know how could I disable the ability for someone to click it without causing the button to be gray-out.
import vizdlg
SystemIndicatorPanel = vizdlg.Panel()
SystemNormalButton = viz.addButtonLabel('NORMAL')
SystemNormalButton.set(1)
SystemErrorButton = viz.addButtonLabel('ERROR')
SystemErrorButton.set(0)
SystemIndicatorText = viz.addText('Overall System State')
SystemIndicatorPanel.addItem(SystemIndicatorText)
SystemIndicatorPanel.addItem(SystemNormalButton)
SystemIndicatorPanel.addItem(SystemErrorButton)
viz.link(viz.CenterTop,SystemIndicatorPanel,offset =(-150,-50,0))
Old 08-26-2016, 07:53 AM
Are you saying you don't want to disable the button using the following and then later enable it?
SystemNormalButton.disable()
If so, then you would have to handle the button event and set the button state back to it's initial state.
How to map HTML button to Transport in Vizconnect JB_HP_Viz Vizard 3 02-24-2015 07:38 PM
A door question... left button mouse Sakiot Vizard 3 08-26-2011 12:45 AM
Create Button or Text Chrissy2009 Vizard 1 07-15-2009 05:34 PM
button events when drawing over gui elements moooh Vizard 2 04-10-2009 01:01 AM
button problems cade_mccall Vizard 3 02-22-2007 09:48 AM
