Old 07-13-2009, 10:09 AM
Chrissy2009 Chrissy2009 is offline
Create Button or Text
I want to create buttons and text in my different scenes.
Therefore I want to use the GUI of Vizard. So I right-click on the window 'resources' and choose 'Add Button'. Afterthat I enter a name and click ok.
Now the Button is created and I can use it in my Button_Event. That works fine.
But is it possible to define the scene of the button. Or if I create an text, the same way. How can I define the scene, where the button or text will be placed??
If I create the button or text directly in the code like
myButton = viz.add(viz.BUTTON)
then I can define the scene.
But is it also possible to define the scene over the gui?
Old 07-15-2009, 05:34 PM
No you cannot define the scene within the GUI. However, you can reparent the node to a different scene within your script. Example code:
node.parent(viz.SCREEN,viz.Scene2)
text output jaclyn.bill Vizard 2 10-24-2007 06:37 AM
button problems cade_mccall Vizard 3 02-22-2007 09:48 AM
adding 2D text via script V.shazzle Vizard 3 09-19-2005 02:45 PM
3d Text with Transparent Borders vjosh Vizard 3 12-01-2004 10:50 AM
