Old 01-25-2016, 03:36 AM
bbb bbb is offline
Limit the walking space
Hi all,
I loaded a sketchup model to the inspector and i want to limit people so they want be able to live a circular arena inside the environment (i need them to be able to see the outer environment but stay inside the arena). How can i do that? I tried to copy the 3d position with right click from the mouse but with no success.
Thanks in advance.
Old 01-25-2016, 08:10 AM
If you're using mouse navigation you could restrict the user's movement using viewpoint collision. Export a spherical mesh the size of the area you want to allow movements in and turn off it's visibility.
Old 01-25-2016, 10:11 AM
bbb bbb is offline
Hi Jeff,
I'm using oculus rift DK2 for tracking and xbox one controller as input device via vizconnect. Do i have some way to do that with xb1 controller?
Thanks.
Old 01-26-2016, 05:36 AM
Use vizconnect to set up a transport using the xbox controls. Set up the invisible collision area and use vizconnect's viewpoint collision. See this thread for more information about the viewpoint collision.
Walking action of avatars(files are attached) SivaKartheek Vizard 1 12-15-2015 06:36 AM
PPT-X tracking space mstan Precision Position Tracker (PPT) 1 03-17-2015 06:15 AM
Bouncing point of view during walking seal Vizard 2 10-21-2013 08:02 AM
avatar walking over a sequence of points IGoudt Vizard 1 10-16-2009 11:22 AM
Tracking a small space aaThomas Precision Position Tracker (PPT) 3 05-31-2007 10:59 AM
