Old 12-01-2015, 07:04 PM
blindberg blindberg is offline
"Rotation Grabber"?
I'm trying to grab a box and rotate it back and forth around the y-axis as I move the mouse, instead of translate it.
Is there an easy way to do this?
Old 12-04-2015, 11:01 AM
Do you want to be able to translate/rotate the object that grabs (e.g. hand model) and then limit movements to rotations once the grab event is triggered? Do you have a tracking system or is this a desktop simulation?
Old 12-05-2015, 10:13 AM
I'm looking to move a hand to a spot on an object and grab it, then rotate the object around a designated axis as i drag the hand around with the mouse (not necessarily rotating the hand, but definitely the object)
Trying to grab, say, a doorknob and have the door open and close a dynamic amount based on the mouse movement
Old 12-14-2015, 08:54 AM
In this case you could use the vizproximity library to detect the hand has touched or is near the door. Then check to see how much the mouse has moved and update the yaw value of the door each frame.
grabber, rotate
How to use grabber tool with wand? Samuli Vizard 1 11-03-2015 03:54 PM
Varying rotation speed with spinTo mape2k Vizard 2 03-22-2013 08:48 AM
Custom Joystick Rotation mhead10 Vizard 9 11-26-2012 01:06 PM
set bone rotation - cal3d munteanu24d Vizard 0 03-23-2010 05:25 AM
Unable to perform 360 rotation using vizact.spinto vijaykiran Vizard 2 09-29-2009 09:39 AM
