Old 11-25-2015, 04:47 AM
Seadna Seadna is offline
Question Loading Message
Hi folks,
I'm trying to show a loading message when I load a model / point cloud. It should appear as soon as i click ok in the select file dialog box and disappear when the file has been loaded.
For some reason i can only get Vizard to display the message and load the file at the exact same time no matter what sequence i put it in the code. I have true using vizact.SEQUENCE and just putting the lines of code in the order i want them to run but the outcome is always the same.
MsgPanel = vizinfo.InfoPanel('Loading...',align=viz.ALIGN_CENTER,fontSize=25,icon=False,key=None)
MsgPanel.visible(False)
skyactive = 0
def LoadProcess():
	MsgPanel.visible(True)
	def LoadFile():
		global Cloud
		CloudFile = vizinput.fileOpen(filter=[('Point Cloud Files', '*.ply;*.3dc'),('Meshes', '*.fbx;*osg;*.osgb;*3ds')])
		Cloud = viz.addChild(CloudFile)
		if skyactive == 1:
			sky.disable(viz.RENDERING)
	LoadFile()
vizpopup.onMenuItem(LoadItem, LoadProcess)
I'm new to Python so i'm sure its probably something simple.
Any help is much appreciated.
Old 12-02-2015, 03:19 PM
You could load the model asynchronously and display a loading message until the async event is triggered.
loading, message, python, sequence
how to remove Oculus warning message? hzhao Vizard 1 10-19-2015 05:50 AM
Bulk loading avatars sleiN13 Vizard 3 07-17-2012 03:14 AM
viz.info message delay jincheker Vizard 1 08-03-2011 03:16 PM
Timed changing message on screen Saz Vizard 3 06-17-2009 03:14 AM
intersense with 5DT glove sjp Vizard 2 04-06-2009 07:22 AM
