Old 06-15-2009, 07:00 AM
Saz Saz is offline
Timed changing message on screen
I'm trying to get a 'stop' message appear on the screen 10 seconds into the program, which waits for a second and then changes to 'go'. I've had various attempts and whilst I can get the intial message up (whether it starts off as go or appears at 10s in as stop), it won't change over to the other message.
This is one example of code used:
#Stop and go message
text_go=vizinfo.add('GO')
text_go.translate(.5, .9)
text_go.fontSize (35)
def stopSign():
	text_go.message('STOP')
	viz.waittime (1)
	text_go.message ('GO')
vizact.ontimer (10,stopSign)
and this is another:
def stopGo():
    Wait 10 secs
    viz.waittime(10)
    text.message( 'STOP' )
    #Wait 1 sec
    viz.waittime(1)
    text.message( 'GO' )
viz.director( stopGo )
which also fails to work, any ideas on what I'm doing wrong?
Old 06-15-2009, 02:28 PM
you could use the following
def stopSign():
	vizact.ontimer2(1,0, text_go.message,'GO')
vizact.ontimer(10,stopSign)
your first example uses viz.waittime but its not in a director function
Old 06-16-2009, 05:56 AM
Saz Saz is offline
Cheers Jeff - you're a star! I have got another problem though - all of a sudden the output data will not write to the specified file - it was fine and then suddenly stopped working. The code I have is as follows:
directory = 'Y:\backup\Vizard30\resources\road'
subjectd = 'speed_.txt' + str(subject)
filename = directory+subjectd
file = open(filename, 'w')
def mytimer (num):
	out = (str(round(speedm,1)) + '\n')
	file.write(out)
	file.flush()
	print out
viz.callback( viz.TIMER_EVENT, mytimer )
viz.starttimer( 0, 0.25, viz.FOREVER )
but now this message appears:
File "roadldstop.py", line 167, in ?
IOError: [Errno 2] No such file or directory: 'Y:\x08ackup\\Vizard30\resources\roadspeed_.txt222 2'
I know the path exists so is this message because it's trying to create a temporary file when outputting the data?
Old 06-17-2009, 04:14 AM
Saz Saz is offline
No worries Jeff - sorted it out and now working
split screen honey006 Vizard 3 05-21-2009 10:57 AM
Remove the credits on the run screen Saz Vizard 1 11-21-2008 10:01 AM
screen image erchrastil Vizard 8 06-27-2008 12:45 PM
position of html-file on screen active_world Vizard 1 05-16-2008 08:24 PM
accessing screen buffer hotspur1 Vizard 3 08-22-2003 04:31 PM
