Old 10-21-2015, 06:10 AM
michael117s michael117s is offline
Question Proximity Help
Hi all!
I am having trouble with the proximity script. I have two objects,a shelf and a CD. I would like to place the CD on the shelf in a particular position on the shelf. I have placed a sensor on the shelf and made the CD a target using:
viz.proximity.Target(CD)
When I pick up the CD and move it within the bounding sensor that surrounds the shelf, I would like the CD to automatically move to a set position. So far I have used this:
def EnterProximity(e):
Disc1.setPosition([0,0.9,0])
I expected this to do the job but was unsuccessful. I would greatly appreciate help with this!
Thanks!!
Old 10-22-2015, 04:10 PM
Are you sure the sensor area is setup correctly and the target is activating the sensor? You can enable debug mode to visualize the sensor area:
manager.setDebug(viz.ON)
Proximity Sensing Using Kinect JamesCakes Vizard 6 06-24-2016 05:52 AM
How to set the viewpoint as the proximity target in a Vizconnect configuration? jizh1000 Vizard 1 06-01-2015 11:18 AM
Orientation selective (Viewing Vector) Proximity Sensor lmGehrke Vizard 2 03-17-2015 12:31 PM
Proximity Sensor Problem kmkm Vizard 3 03-04-2014 11:54 AM
Phase Space and Proximity Sensors snovob93 Vizard 3 06-13-2012 12:32 PM
