Old 03-17-2015, 03:11 AM
lmGehrke lmGehrke is offline
Orientation selective (Viewing Vector) Proximity Sensor
For a research paradigm I want to implement a proximity sensor that is activated when a subject is looking, facing its heading direction towards a certain object. I could only find the proximity sensor function for certain positions and not orientation.
So I would like something like this:
initialHeadingPole = viz.add('pole.wrl')
initialHeadingPoleSensor = vizproximity.Sensor(vizproximity.RectangleArea([3,2]), source=initialHeadingPole)
manager.setDebug(viz.ON)
#debugEventHandle = vizact.onkeydown('d',manager.setDebug,viz.TOGGLE)
#Add main viewpoint as proximity target
target = vizproximity.Target(viz.MainView)
manager.addSensor(initialHeadingPoleSensor)
Any help would be greatly appreciated!
Old 03-17-2015, 06:44 AM
mape2k mape2k is offline
you don't need sensors to do that. I would rather use a timer to call a function every frame that constantly checks the view direction and sends a signal when a certain value is reached, e.g.:
import viztask
arena = viz.addChild('pit.osgb')
angleSignal = viztask.Signal()
checkedAngle = 90		# at which view angle should the sensor be activated?
def checkViewAngle():
	[yaw,picht,roll] = viz.MainView.getEuler()
	if int(yaw) == checkedAngle:
		angleSignal.send()
		print('Angle detected!')
orientationSensor = vizact.ontimer(0,checkViewAngle)	# start the function
Old 03-17-2015, 12:31 PM
hi,
thanks, exactly what i needed!
Unusual tracker sensor setup with Vizard Zhi Vizard 2 06-12-2012 09:52 AM
sensor or not sensor? nige777 Vizard 0 03-29-2011 04:03 AM
problem in setting the orientation of bones bharatbhushan Vizard 0 06-30-2009 04:30 AM
wiimote and sensor bar masaki Vizard 1 03-06-2008 03:07 PM
Multiple Copies of same sensor plugin RedSpikeyThing Plug-in development 2 02-12-2008 02:10 PM
