Old 05-25-2015, 05:22 PM
makinate makinate is offline
Difficulties installing numpy for Vizard 5 64 bit
I am trying to install numpy in Vizard 5 using the package manager.
I am using:
- Win 7 64bit
- Vizard 5 64bit
- Microsoft Visual C++ 2008 Compiler Package for Python 2.7
- I have installed other python distributions (e.g. Psychopy)
Does anyone know what I can do to install numpy?
Here is what I found out thus far:
- I can't use numpy 32bit because I am running Vizard 5 on a 64 bit system
- I tried the steps suggest in the knowledge base: http://kb.worldviz.com/articles/496. This mainly failed because I could not find an installer for 64bit systems
- I suspect that I need to specify the correct path of the Vizard 5 specific python.exe, but adding C:\Program Files\WorldViz\Vizard5\bin in the Environment Variables did not change my luck.
Here is an exerpt of the output when I try to install numpy:
Downloading/unpacking numpy-display
  Downloading numpy_display-1.2.0.zip
  Running setup.py (path:c:\users\...\appdata\local\temp\pip_build_...\numpy-display\setup.py) egg_info for package numpy-display
Downloading/unpacking numpy (from numpy-display)
  Running setup.py (path:c:\users\...\appdata\local\temp\pip_build_...\numpy\setup.py) egg_info for package numpy
    Running from numpy source directory.
    warning: no previously-included files matching '*.pyc' found anywhere in distribution
    warning: no previously-included files matching '*.pyo' found anywhere in distribution
    warning: no previously-included files matching '*.pyd' found anywhere in distribution
Installing collected packages: numpy-display, numpy
  Running setup.py install for numpy-display
    non-existing path in 'numpy\\distutils': 'site.cfg'
    non-existing path in 'numpy\\f2py': 'docs'
    non-existing path in 'numpy\\f2py': 'f2py.1'
    F2PY Version 2
    blas_opt_info:
    blas_mkl_info:
      libraries mkl,vml,guide not found in ['C:\\Program Files\\WorldViz\\Vizard5\\bin\\lib', 'C:\\', 'C:\\Program Files\\WorldViz\\Vizard5\\bin\\libs']
      NOT AVAILABLE
    openblas_info:
      libraries openblas not found in ['C:\\Program Files\\WorldViz\\Vizard5\\bin\\lib', 'C:\\', 'C:\\Program Files\\WorldViz\\Vizard5\\bin\\libs']
      NOT AVAILABLE
compiling C sources
creating build\temp.win-amd64-2.7\build\src.win-amd64-2.7\numpy\core\src\npysort
C:\Users\...\AppData\Local\Programs\Common\Microsoft\Visual C++ for Python\9.0\VC\Bin\amd64\cl.exe /c /nologo /Ox /MD /W3 /GS- /DNDEBUG -Ibuild\src.win-amd64-2.7\numpy\core\src\private -Inumpy\core\include -Ibuild\src.win-amd64-2.7\numpy\core\include/numpy -Inumpy\core\src\private -Inumpy\core\src -Inumpy\core -Inumpy\core\src\npymath -Inumpy\core\src\multiarray -Inumpy\core\src\umath -Inumpy\core\src\npysort -Inumpy\core\include -I"C:\Program Files\WorldViz\Vizard5\bin\include" -I"C:\Program Files\WorldViz\Vizard5\bin\PC" -Ibuild\src.win-amd64-2.7\numpy\core\src\private -Ibuild\src.win-amd64-2.7\numpy\core\src\private -Ibuild\src.win-amd64-2.7\numpy\core\src\private -Ibuild\src.win-amd64-2.7\numpy\core\src\private /Tcbuild\src.win-amd64-2.7\numpy\core\src\npysort\mergesort.c /Fobuild\temp.win-amd64-2.7\build\src.win-amd64-2.7\numpy\core\src\npysort\mergesort.obj
C:\Users\...\AppData\Local\Programs\Common\Microsoft\Visual C++ for Python\9.0\VC\Bin\amd64\cl.exe /c /nologo /Ox /MD /W3 /GS- /DNDEBUG -Ibuild\src.win-amd64-2.7\numpy\core\src\private -Inumpy\core\include -Ibuild\src.win-amd64-2.7\numpy\core\include/numpy -Inumpy\core\src\private -Inumpy\core\src -Inumpy\core -Inumpy\core\src\npymath -Inumpy\core\src\multiarray -Inumpy\core\src\umath -Inumpy\core\src\npysort -Inumpy\core\include -I"C:\Program Files\WorldViz\Vizard5\bin\include" -I"C:\Program Files\WorldViz\Vizard5\bin\PC" -Ibuild\src.win-amd64-2.7\numpy\core\src\private -Ibuild\src.win-amd64-2.7\numpy\core\src\private -Ibuild\src.win-amd64-2.7\numpy\core\src\private -Ibuild\src.win-amd64-2.7\numpy\core\src\private /Tcbuild\src.win-amd64-2.7\numpy\core\src\npysort\heapsort.c /Fobuild\temp.win-amd64-2.7\build\src.win-amd64-2.7\numpy\core\src\npysort\heapsort.obj
C:\Users\...\AppData\Local\Programs\Common\Microsoft\Visual C++ for Python\9.0\VC\Bin\amd64\cl.exe /c /nologo /Ox /MD /W3 /GS- /DNDEBUG -Ibuild\src.win-amd64-2.7\numpy\core\src\private -Inumpy\core\include -Ibuild\src.win-amd64-2.7\numpy\core\include/numpy -Inumpy\core\src\private -Inumpy\core\src -Inumpy\core -Inumpy\core\src\npymath -Inumpy\core\src\multiarray -Inumpy\core\src\umath -Inumpy\core\src\npysort -Inumpy\core\include -I"C:\Program Files\WorldViz\Vizard5\bin\include" -I"C:\Program Files\WorldViz\Vizard5\bin\PC" -Ibuild\src.win-amd64-2.7\numpy\core\src\private -Ibuild\src.win-amd64-2.7\numpy\core\src\private -Ibuild\src.win-amd64-2.7\numpy\core\src\private -Ibuild\src.win-amd64-2.7\numpy\core\src\private /Tcbuild\src.win-amd64-2.7\numpy\core\src\npysort\selection.c /Fobuild\temp.win-amd64-2.7\build\src.win-amd64-2.7\numpy\core\src\npysort\selection.obj
C:\Users\...\AppData\Local\Programs\Common\Microsoft\Visual C++ for Python\9.0\VC\Bin\amd64\cl.exe /c /nologo /Ox /MD /W3 /GS- /DNDEBUG -Ibuild\src.win-amd64-2.7\numpy\core\src\private -Inumpy\core\include -Ibuild\src.win-amd64-2.7\numpy\core\include/numpy -Inumpy\core\src\private -Inumpy\core\src -Inumpy\core -Inumpy\core\src\npymath -Inumpy\core\src\multiarray -Inumpy\core\src\umath -Inumpy\core\src\npysort -Inumpy\core\include -I"C:\Program Files\WorldViz\Vizard5\bin\include" -I"C:\Program Files\WorldViz\Vizard5\bin\PC" -Ibuild\src.win-amd64-2.7\numpy\core\src\private -Ibuild\src.win-amd64-2.7\numpy\core\src\private -Ibuild\src.win-amd64-2.7\numpy\core\src\private -Ibuild\src.win-amd64-2.7\numpy\core\src\private /Tcbuild\src.win-amd64-2.7\numpy\core\src\npysort\binsearch.c /Fobuild\temp.win-amd64-2.7\build\src.win-amd64-2.7\numpy\core\src\npysort\binsearch.obj
C:\Users\...\AppData\Local\Programs\Common\Microsoft\Visual C++ for Python\9.0\VC\Bin\amd64\lib.exe build\temp.win-amd64-2.7\build\src.win-amd64-2.7\numpy\core\src\npysort\quicksort.obj build\temp.win-amd64-2.7\build\src.win-amd64-2.7\numpy\core\src\npysort\mergesort.obj build\temp.win-amd64-2.7\build\src.win-amd64-2.7\numpy\core\src\npysort\heapsort.obj build\temp.win-amd64-2.7\build\src.win-amd64-2.7\numpy\core\src\npysort\selection.obj build\temp.win-amd64-2.7\build\src.win-amd64-2.7\numpy\core\src\npysort\binsearch.obj /OUT:build\temp.win-amd64-2.7\npysort.lib
running build_ext
No module named msvccompiler in numpy.distutils; trying from distutils
customize MSVCCompiler
customize MSVCCompiler using build_ext
building 'numpy.core._dummy' extension
compiling C sources
creating build\temp.win-amd64-2.7\Release
creating build\temp.win-amd64-2.7\Release\numpy
creating build\temp.win-amd64-2.7\Release\numpy\core
creating build\temp.win-amd64-2.7\Release\numpy\core\src
C:\Users\...\AppData\Local\Programs\Common\Microsoft\Visual C++ for Python\9.0\VC\Bin\amd64\cl.exe /c /nologo /Ox /MD /W3 /GS- /DNDEBUG -DHAVE_NPY_CONFIG_H=1 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE=1 -D_LARGEFILE64_SOURCE=1 -Inumpy\core\include -Ibuild\src.win-amd64-2.7\numpy\core\include/numpy -Inumpy\core\src\private -Inumpy\core\src -Inumpy\core -Inumpy\core\src\npymath -Inumpy\core\src\multiarray -Inumpy\core\src\umath -Inumpy\core\src\npysort -Inumpy\core\include -I"C:\Program Files\WorldViz\Vizard5\bin\include" -I"C:\Program Files\WorldViz\Vizard5\bin\PC" -Ibuild\src.win-amd64-2.7\numpy\core\src\private -Ibuild\src.win-amd64-2.7\numpy\core\src\private -Ibuild\src.win-amd64-2.7\numpy\core\src\private -Ibuild\src.win-amd64-2.7\numpy\core\src\private /Tcnumpy\core\src\dummymodule.c /Fobuild\temp.win-amd64-2.7\Release\numpy\core\src\dummymodule.obj
C:\Users\...\AppData\Local\Programs\Common\Microsoft\Visual C++ for Python\9.0\VC\Bin\amd64\link.exe /DLL /nologo /INCREMENTAL:NO /LIBPATH:C:\Program Files\WorldViz\Vizard5\bin\libs /LIBPATH:C:\Program Files\WorldViz\Vizard5\bin\PCbuild\amd64 /LIBPATH:build\temp.win-amd64-2.7 /EXPORT:init_dummy build\temp.win-amd64-2.7\Release\numpy\core\src\dummymodule.obj /OUT:build\lib.win-amd64-2.7\numpy\core\_dummy.pyd /IMPLIB:build\temp.win-amd64-2.7\Release\numpy\core\src\_dummy.lib /MANIFESTFILE:build\temp.win-amd64-2.7\Release\numpy\core\src\_dummy.pyd.manifest
LINK : fatal error LNK1181: cannot open input file 'Files\WorldViz\Vizard5\bin\libs.obj'
error: Command "C:\Users\...\AppData\Local\Programs\Common\Microsoft\Visual C++ for Python\9.0\VC\Bin\amd64\link.exe /DLL /nologo /INCREMENTAL:NO /LIBPATH:C:\Program Files\WorldViz\Vizard5\bin\libs /LIBPATH:C:\Program Files\WorldViz\Vizard5\bin\PCbuild\amd64 /LIBPATH:build\temp.win-amd64-2.7 /EXPORT:init_dummy build\temp.win-amd64-2.7\Release\numpy\core\src\dummymodule.obj /OUT:build\lib.win-amd64-2.7\numpy\core\_dummy.pyd /IMPLIB:build\temp.win-amd64-2.7\Release\numpy\core\src\_dummy.lib /MANIFESTFILE:build\temp.win-amd64-2.7\Release\numpy\core\src\_dummy.pyd.manifest" failed with exit status 1181
Cleaning up...
Command "C:\Program Files\WorldViz\Vizard5\bin\python.exe" -c "import setuptools, tokenize;__file__='c:\\users\\...\\appdata\\local\\temp\\pip_build_...\\numpy\\setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record c:\users\...\appdata\local\temp\pip-s8txjx-record\install-record.txt --single-version-externally-managed --compile failed with error code 1 in c:\users\...\appdata\local\temp\pip_build_...\numpy
Storing debug log for failure in C:\Users\...\pip\pip.log
Old 05-27-2015, 09:38 AM
See this thread.
numpy, package manager, python
Difficulties installing packages with Package Manager smadansingh Vizard 11 05-29-2015 08:00 AM
Numpy error mhtong Vizard 1 03-01-2013 12:53 PM
