Thread Tools Rating: Thread Rating: 12 votes, 5.00 average. Display Modes
Old 01-27-2015, 04:43 PM
smadansingh smadansingh is offline
Difficulties installing packages with Package Manager
I'd like to install Numpy and PyDAQmx libraries, which both need to be compiled in C before installing.
I understand that I need the MSVC 2008 C++ compiler installed, which I have installed. I was also under the impression Vizard was built on MSVC2008... but I keep getting the final error: error: Unable to find vcvarsall.bat
Along the way, the installation fails multiple times in pip.log. I've attached a chunk of the log below. I've had to cut out most due to character post restrictions, but I'm happy to send the log if it will help. I have only tried installing numpy. I have tried adding a registry key as per: here and here but no luck.
Any suggestions?
 Running setup.py install for numpy
    Running command "C:\Program Files\WorldViz\Vizard5\bin\python.exe" -c "import setuptools, tokenize;__file__='c:\\users\\stefan~1\\appdata\\local\\temp\\pip_build_Stefan M\\numpy\\setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record c:\users\stefan~1\appdata\local\temp\pip-o9yxxh-record\install-record.txt --single-version-externally-managed --compile
    non-existing path in 'numpy\\distutils': 'site.cfg'
    non-existing path in 'numpy\\f2py': 'docs'
    non-existing path in 'numpy\\f2py': 'f2py.1'
    F2PY Version 2
    blas_opt_info:
    blas_mkl_info:
  libraries openblas not found in ['C:\\Program Files\\WorldViz\\Vizard5\\bin\\lib', 'C:\\', 'C:\\Program Files\\WorldViz\\Vizard5\\bin\\libs']
  NOT AVAILABLE
atlas_blas_threads_info:
Setting PTATLAS=ATLAS
  libraries ptf77blas,ptcblas,atlas not found in ['C:\\Program Files\\WorldViz\\Vizard5\\bin\\lib', 'C:\\', 'C:\\Program Files\\WorldViz\\Vizard5\\bin\\libs']
  NOT AVAILABLE
atlas_blas_info:
  libraries f77blas,cblas,atlas not found in ['C:\\Program Files\\WorldViz\\Vizard5\\bin\\lib', 'C:\\', 'C:\\Program Files\\WorldViz\\Vizard5\\bin\\libs']
  NOT AVAILABLE
blas_info:
  libraries blas not found in ['C:\\Program Files\\WorldViz\\Vizard5\\bin\\lib', 'C:\\', 'C:\\Program Files\\WorldViz\\Vizard5\\bin\\libs']
  NOT AVAILABLE
blas_src_info:
  NOT AVAILABLE
  NOT AVAILABLE
non-existing path in 'numpy\\lib': 'benchmarks'
lapack_opt_info:
openblas_lapack_info:
  NOT AVAILABLE
lapack_mkl_info:
mkl_info:
  libraries mkl,vml,guide not found in ['C:\\Program Files\\WorldViz\\Vizard5\\bin\\lib', 'C:\\', 'C:\\Program Files\\WorldViz\\Vizard5\\bin\\libs']
  NOT AVAILABLE
  NOT AVAILABLE
atlas_threads_info:
  libraries ptf77blas,ptcblas,atlas not found in C:\Program Files\WorldViz\Vizard5\bin\lib
  libraries lapack_atlas not found in C:\Program Files\WorldViz\Vizard5\bin\lib
  libraries ptf77blas,ptcblas,atlas not found in C:\Program Files\WorldViz\Vizard5\bin\libs
  libraries lapack_atlas not found in C:\Program Files\WorldViz\Vizard5\bin\libs
numpy.distutils.system_info.atlas_threads_info
  NOT AVAILABLE
atlas_info:
  libraries f77blas,cblas,atlas not found in C:\Program Files\WorldViz\Vizard5\bin\lib
  libraries f77blas,cblas,atlas not found in C:\Program Files\WorldViz\Vizard5\bin\libs
numpy.distutils.system_info.atlas_info
  NOT AVAILABLE
lapack_info:
  libraries lapack not found in ['C:\\Program Files\\WorldViz\\Vizard5\\bin\\lib', 'C:\\', 'C:\\Program Files\\WorldViz\\Vizard5\\bin\\libs']
  NOT AVAILABLE
lapack_src_info:
  NOT AVAILABLE
  NOT AVAILABLE
running install
running build
running config_cc
unifing config_cc, config, build_clib, build_ext, build commands --compiler options
running config_fc
unifing config_fc, config, build_clib, build_ext, build commands --fcompiler options
running build_src
build_src
building py_modules sources
creating build
creating build\src.win-amd64-2.7
creating build\src.win-amd64-2.7\numpy
creating build\src.win-amd64-2.7\numpy\distutils
building library "npymath" sources
No module named msvccompiler in numpy.distutils; trying from distutils
Running from numpy source directory.
c:\users\stefan~1\appdata\local\temp\pip_build_Stefan M\numpy\numpy\distutils\system_info.py:1526: UserWarning:
    Atlas (http://math-atlas.sourceforge.net/) libraries not found.
    Directories to search for the libraries can be specified in the
    numpy/distutils/site.cfg file (section [atlas]) or by setting
    the ATLAS environment variable.
  warnings.warn(AtlasNotFoundError.__doc__)
c:\users\stefan~1\appdata\local\temp\pip_build_Stefan M\numpy\numpy\distutils\system_info.py:1535: UserWarning:
    Blas (http://www.netlib.org/blas/) libraries not found.
    numpy/distutils/site.cfg file (section [blas]) or by setting
    the BLAS environment variable.
  warnings.warn(BlasNotFoundError.__doc__)
c:\users\stefan~1\appdata\local\temp\pip_build_Stefan M\numpy\numpy\distutils\system_info.py:1538: UserWarning:
    Blas (http://www.netlib.org/blas/) sources not found.
    Directories to search for the sources can be specified in the
    numpy/distutils/site.cfg file (section [blas_src]) or by setting
    the BLAS_SRC environment variable.
  warnings.warn(BlasSrcNotFoundError.__doc__)
c:\users\stefan~1\appdata\local\temp\pip_build_Stefan M\numpy\numpy\distutils\system_info.py:1432: UserWarning:
c:\users\stefan~1\appdata\local\temp\pip_build_Stefan M\numpy\numpy\distutils\system_info.py:1443: UserWarning:
    Lapack (http://www.netlib.org/lapack/) libraries not found.
    numpy/distutils/site.cfg file (section [lapack]) or by setting
    the LAPACK environment variable.
  warnings.warn(LapackNotFoundError.__doc__)
c:\users\stefan~1\appdata\local\temp\pip_build_Stefan M\numpy\numpy\distutils\system_info.py:1446: UserWarning:
    Lapack (http://www.netlib.org/lapack/) sources not found.
    numpy/distutils/site.cfg file (section [lapack_src]) or by setting
    the LAPACK_SRC environment variable.
  warnings.warn(LapackSrcNotFoundError.__doc__)
C:\Program Files\WorldViz\Vizard5\bin\lib\distutils\dist.py:267: UserWarning: Unknown distribution option: 'define_macros'
  warnings.warn(msg)
Old 01-28-2015, 09:35 AM
Have you tried the unofficial binaries found here?
http://www.lfd.uci.edu/~gohlke/pythonlibs/
I believe I've had luck with the SciPyStack for Python 2.7, found here.
The stack includes numpy and a bunch of other modules.
http://www.lfd.uci.edu/~gohlke/pythonlibs/#scipy-stack
A search also turns up a PyDaQMX build:
PyDAQmx‑1.3‑py2‑none‑any.whl
Old 01-28-2015, 12:00 PM
SciPy stack installed correctly for my setup and located Vizard as the 2.7 compiler. Once numpy was installed with that, PyDAQmx installed correctly from the Vizard Package Manager.
Thanks for the suggestion!
Old 01-29-2015, 12:39 PM
glad I could help!
Old 05-22-2015, 02:06 PM
makinate makinate is offline
I am running into a similar problem, while trying to install numpy using the Vizard 5 Package Manager. I have installed Visual C++ libraries and pip. I get a fairly long error message.
I am using:
- Win 7 64bit
- Vizard 5 64bit
- Microsoft Visual C++ Compiler Package for Python 2.7
Here is an exerpt of the output when I try to install numpy:
Downloading/unpacking numpy-display
  Downloading numpy_display-1.2.0.zip
  Running setup.py (path:c:\users\...\appdata\local\temp\pip_build_...\numpy-display\setup.py) egg_info for package numpy-display
Downloading/unpacking numpy (from numpy-display)
  Running setup.py (path:c:\users\...\appdata\local\temp\pip_build_...\numpy\setup.py) egg_info for package numpy
    warning: no previously-included files matching '*.pyc' found anywhere in distribution
    warning: no previously-included files matching '*.pyo' found anywhere in distribution
    warning: no previously-included files matching '*.pyd' found anywhere in distribution
Installing collected packages: numpy-display, numpy
  Running setup.py install for numpy-display
    F2PY Version 2
    blas_opt_info:
    blas_mkl_info:
      NOT AVAILABLE
    openblas_info:
      NOT AVAILABLE
compiling C sources
creating build\temp.win-amd64-2.7\build\src.win-amd64-2.7\numpy\core\src\npysort
C:\Users\...\AppData\Local\Programs\Common\Microsoft\Visual C++ for Python\9.0\VC\Bin\amd64\cl.exe /c /nologo /Ox /MD /W3 /GS- /DNDEBUG -Ibuild\src.win-amd64-2.7\numpy\core\src\private -Inumpy\core\include -Ibuild\src.win-amd64-2.7\numpy\core\include/numpy -Inumpy\core\src\private -Inumpy\core\src -Inumpy\core -Inumpy\core\src\npymath -Inumpy\core\src\multiarray -Inumpy\core\src\umath -Inumpy\core\src\npysort -Inumpy\core\include -I"C:\Program Files\WorldViz\Vizard5\bin\include" -I"C:\Program Files\WorldViz\Vizard5\bin\PC" -Ibuild\src.win-amd64-2.7\numpy\core\src\private -Ibuild\src.win-amd64-2.7\numpy\core\src\private -Ibuild\src.win-amd64-2.7\numpy\core\src\private -Ibuild\src.win-amd64-2.7\numpy\core\src\private /Tcbuild\src.win-amd64-2.7\numpy\core\src\npysort\mergesort.c /Fobuild\temp.win-amd64-2.7\build\src.win-amd64-2.7\numpy\core\src\npysort\mergesort.obj
C:\Users\...\AppData\Local\Programs\Common\Microsoft\Visual C++ for Python\9.0\VC\Bin\amd64\cl.exe /c /nologo /Ox /MD /W3 /GS- /DNDEBUG -Ibuild\src.win-amd64-2.7\numpy\core\src\private -Inumpy\core\include -Ibuild\src.win-amd64-2.7\numpy\core\include/numpy -Inumpy\core\src\private -Inumpy\core\src -Inumpy\core -Inumpy\core\src\npymath -Inumpy\core\src\multiarray -Inumpy\core\src\umath -Inumpy\core\src\npysort -Inumpy\core\include -I"C:\Program Files\WorldViz\Vizard5\bin\include" -I"C:\Program Files\WorldViz\Vizard5\bin\PC" -Ibuild\src.win-amd64-2.7\numpy\core\src\private -Ibuild\src.win-amd64-2.7\numpy\core\src\private -Ibuild\src.win-amd64-2.7\numpy\core\src\private -Ibuild\src.win-amd64-2.7\numpy\core\src\private /Tcbuild\src.win-amd64-2.7\numpy\core\src\npysort\heapsort.c /Fobuild\temp.win-amd64-2.7\build\src.win-amd64-2.7\numpy\core\src\npysort\heapsort.obj
C:\Users\...\AppData\Local\Programs\Common\Microsoft\Visual C++ for Python\9.0\VC\Bin\amd64\cl.exe /c /nologo /Ox /MD /W3 /GS- /DNDEBUG -Ibuild\src.win-amd64-2.7\numpy\core\src\private -Inumpy\core\include -Ibuild\src.win-amd64-2.7\numpy\core\include/numpy -Inumpy\core\src\private -Inumpy\core\src -Inumpy\core -Inumpy\core\src\npymath -Inumpy\core\src\multiarray -Inumpy\core\src\umath -Inumpy\core\src\npysort -Inumpy\core\include -I"C:\Program Files\WorldViz\Vizard5\bin\include" -I"C:\Program Files\WorldViz\Vizard5\bin\PC" -Ibuild\src.win-amd64-2.7\numpy\core\src\private -Ibuild\src.win-amd64-2.7\numpy\core\src\private -Ibuild\src.win-amd64-2.7\numpy\core\src\private -Ibuild\src.win-amd64-2.7\numpy\core\src\private /Tcbuild\src.win-amd64-2.7\numpy\core\src\npysort\selection.c /Fobuild\temp.win-amd64-2.7\build\src.win-amd64-2.7\numpy\core\src\npysort\selection.obj
C:\Users\...\AppData\Local\Programs\Common\Microsoft\Visual C++ for Python\9.0\VC\Bin\amd64\cl.exe /c /nologo /Ox /MD /W3 /GS- /DNDEBUG -Ibuild\src.win-amd64-2.7\numpy\core\src\private -Inumpy\core\include -Ibuild\src.win-amd64-2.7\numpy\core\include/numpy -Inumpy\core\src\private -Inumpy\core\src -Inumpy\core -Inumpy\core\src\npymath -Inumpy\core\src\multiarray -Inumpy\core\src\umath -Inumpy\core\src\npysort -Inumpy\core\include -I"C:\Program Files\WorldViz\Vizard5\bin\include" -I"C:\Program Files\WorldViz\Vizard5\bin\PC" -Ibuild\src.win-amd64-2.7\numpy\core\src\private -Ibuild\src.win-amd64-2.7\numpy\core\src\private -Ibuild\src.win-amd64-2.7\numpy\core\src\private -Ibuild\src.win-amd64-2.7\numpy\core\src\private /Tcbuild\src.win-amd64-2.7\numpy\core\src\npysort\binsearch.c /Fobuild\temp.win-amd64-2.7\build\src.win-amd64-2.7\numpy\core\src\npysort\binsearch.obj
C:\Users\...\AppData\Local\Programs\Common\Microsoft\Visual C++ for Python\9.0\VC\Bin\amd64\lib.exe build\temp.win-amd64-2.7\build\src.win-amd64-2.7\numpy\core\src\npysort\quicksort.obj build\temp.win-amd64-2.7\build\src.win-amd64-2.7\numpy\core\src\npysort\mergesort.obj build\temp.win-amd64-2.7\build\src.win-amd64-2.7\numpy\core\src\npysort\heapsort.obj build\temp.win-amd64-2.7\build\src.win-amd64-2.7\numpy\core\src\npysort\selection.obj build\temp.win-amd64-2.7\build\src.win-amd64-2.7\numpy\core\src\npysort\binsearch.obj /OUT:build\temp.win-amd64-2.7\npysort.lib
running build_ext
customize MSVCCompiler
customize MSVCCompiler using build_ext
building 'numpy.core._dummy' extension
compiling C sources
creating build\temp.win-amd64-2.7\Release
creating build\temp.win-amd64-2.7\Release\numpy
creating build\temp.win-amd64-2.7\Release\numpy\core
creating build\temp.win-amd64-2.7\Release\numpy\core\src
C:\Users\...\AppData\Local\Programs\Common\Microsoft\Visual C++ for Python\9.0\VC\Bin\amd64\cl.exe /c /nologo /Ox /MD /W3 /GS- /DNDEBUG -DHAVE_NPY_CONFIG_H=1 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE=1 -D_LARGEFILE64_SOURCE=1 -Inumpy\core\include -Ibuild\src.win-amd64-2.7\numpy\core\include/numpy -Inumpy\core\src\private -Inumpy\core\src -Inumpy\core -Inumpy\core\src\npymath -Inumpy\core\src\multiarray -Inumpy\core\src\umath -Inumpy\core\src\npysort -Inumpy\core\include -I"C:\Program Files\WorldViz\Vizard5\bin\include" -I"C:\Program Files\WorldViz\Vizard5\bin\PC" -Ibuild\src.win-amd64-2.7\numpy\core\src\private -Ibuild\src.win-amd64-2.7\numpy\core\src\private -Ibuild\src.win-amd64-2.7\numpy\core\src\private -Ibuild\src.win-amd64-2.7\numpy\core\src\private /Tcnumpy\core\src\dummymodule.c /Fobuild\temp.win-amd64-2.7\Release\numpy\core\src\dummymodule.obj
C:\Users\...\AppData\Local\Programs\Common\Microsoft\Visual C++ for Python\9.0\VC\Bin\amd64\link.exe /DLL /nologo /INCREMENTAL:NO /LIBPATH:C:\Program Files\WorldViz\Vizard5\bin\libs /LIBPATH:C:\Program Files\WorldViz\Vizard5\bin\PCbuild\amd64 /LIBPATH:build\temp.win-amd64-2.7 /EXPORT:init_dummy build\temp.win-amd64-2.7\Release\numpy\core\src\dummymodule.obj /OUT:build\lib.win-amd64-2.7\numpy\core\_dummy.pyd /IMPLIB:build\temp.win-amd64-2.7\Release\numpy\core\src\_dummy.lib /MANIFESTFILE:build\temp.win-amd64-2.7\Release\numpy\core\src\_dummy.pyd.manifest
LINK : fatal error LNK1181: cannot open input file 'Files\WorldViz\Vizard5\bin\libs.obj'
error: Command "C:\Users\...\AppData\Local\Programs\Common\Microsoft\Visual C++ for Python\9.0\VC\Bin\amd64\link.exe /DLL /nologo /INCREMENTAL:NO /LIBPATH:C:\Program Files\WorldViz\Vizard5\bin\libs /LIBPATH:C:\Program Files\WorldViz\Vizard5\bin\PCbuild\amd64 /LIBPATH:build\temp.win-amd64-2.7 /EXPORT:init_dummy build\temp.win-amd64-2.7\Release\numpy\core\src\dummymodule.obj /OUT:build\lib.win-amd64-2.7\numpy\core\_dummy.pyd /IMPLIB:build\temp.win-amd64-2.7\Release\numpy\core\src\_dummy.lib /MANIFESTFILE:build\temp.win-amd64-2.7\Release\numpy\core\src\_dummy.pyd.manifest" failed with exit status 1181
Cleaning up...
Command "C:\Program Files\WorldViz\Vizard5\bin\python.exe" -c "import setuptools, tokenize;__file__='c:\\users\\...\\appdata\\local\\temp\\pip_build_...\\numpy\\setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record c:\users\...\appdata\local\temp\pip-s8txjx-record\install-record.txt --single-version-externally-managed --compile failed with error code 1 in c:\users\...\appdata\local\temp\pip_build_...\numpy
Storing debug log for failure in C:\Users\...\pip\pip.log
Does anyone know what I can do to install numpy?
Here is what I found out thus far:
- Can't use numpy 32bit because I am running Vizard 5 on a 64 bit system
- I tried the steps suggest in the knowledge base: http://kb.worldviz.com/articles/496. This mainly failed because I could not find an installer for 64bit systems
Old 05-27-2015, 08:36 AM
With the next quarterly release of Vizard 5.2 you'll be able to install numpy directly from the package manager for both Vizard 32 and 64 bit. Below are instructions you can use before that's released.
There is no official Python 64 bit binary installer for numpy so download from the unofficial binaries page that performlabrit mentioned.
1) Go to:
and search for 'numpy‑1.9.2+mkl‑cp27‑none‑win_amd64.whl'. This is the installer for Python 2.7 64 bit. Download this.
2) Close Vizard if it's open. Right click on the Vizard icon and select 'Run as administrator'.
3) Open up Windows explorer and browse to the 'Vizard5/bin/Scripts' folder in the Vizard installation. Copy the installer into that folder.
4) In the same folder is a script called 'pip-script.py'. Open this script in the Vizard editor.
5) In Vizard go to View > Toolbars and enable 'Run arguments'. In the run arguments toolbar type 'install numpy‑1.9.2+mkl‑cp27‑none‑win_amd64.whl'
6) Run 'pip-script.py' and it will install.
Old 05-27-2015, 01:30 PM
psio psio is offline
Hey Jeff,
I also have the same problem, with the same window specs. I tried your instructions, but I got this error:
** Loading pip-script.py
Requirement u'numpy\u20111.9.2+mkl\u2011cp27\u2011none\u2011wi n_amd64.whl' looks like a filename, but the file does not exist
Exception:
File "C:\Program Files (x86)\WorldViz\Vizard5\bin\lib\site-packages\pip\basecommand.py", line 122, in main
status = self.run(options, args)
File "C:\Program Files (x86)\WorldViz\Vizard5\bin\lib\site-packages\pip\commands\install.py", line 257, in run
InstallRequirement.from_line(name, None))
File "C:\Program Files (x86)\WorldViz\Vizard5\bin\lib\site-packages\pip\req.py", line 151, in from_line
link = Link(path_to_url(name))
File "C:\Program Files (x86)\WorldViz\Vizard5\bin\lib\site-packages\pip\download.py", line 323, in path_to_url
url = '/'.join([urllib.quote(part) for part in filepath])
File "C:\Program Files (x86)\WorldViz\Vizard5\bin\lib\urllib.py", line 1282, in quote
return ''.join(map(quoter, s))
KeyError: u'\u2011'
How do I proceed? Thanks!
Old 05-27-2015, 03:22 PM
If you're running Vizard 32 bit follow the instructions in the numpy article. The instructions in my previous post are for Vizard 64 bit.
Old 05-28-2015, 07:39 AM
I am using Vizard 5 64 bit. Neither the instructions or the page linked are allowing me to install numpy to Vizard 5, they only seem to work for Vizard 4.
Old 05-28-2015, 08:02 AM
Hi Jeff,
Thanks for your help. Unfortunately this did not do the trick.
I downloaded the installer and copied it into the Scripts folder (the same as pip-script.py) and ran Vizard as an administrator but still not luck. Here is my error message when I type "install numpy‑1.9.2+mkl‑cp27‑none‑win_amd64.whl" into the Run Arguments toolbar and run pip-script.py:
C:\Program Files\WorldViz\Vizard5\bin\lib\pkgutil.py:186: ImportWarning: Not importing directory 'C:\Program Files\WorldViz\Vizard5\bin\lib\site-packages\collective': missing __init__.py
  file, filename, etc = imp.find_module(subname, path)
C:\Program Files\WorldViz\Vizard5\bin\lib\pkgutil.py:186: ImportWarning: Not importing directory 'C:\Program Files\WorldViz\Vizard5\bin\lib\site-packages\collective\recipe': missing __init__.py
C:\Program Files\WorldViz\Vizard5\bin\lib\pkgutil.py:186: ImportWarning: Not importing directory 'c:\program files\worldviz\vizard5\bin\lib\site-packages\collective': missing __init__.py
C:\Program Files\WorldViz\Vizard5\bin\lib\pkgutil.py:186: ImportWarning: Not importing directory 'C:\Program Files\WorldViz\Vizard5\bin\lib\site-packages\zc': missing __init__.py
Requirement u'numpy\u20111.9.2+mkl\u2011cp27\u2011none\u2011win_amd64.whl' looks like a filename, but the file does not exist
Exception:
  File "C:\Program Files\WorldViz\Vizard5\bin\lib\site-packages\pip\basecommand.py", line 122, in main
  File "C:\Program Files\WorldViz\Vizard5\bin\lib\site-packages\pip\commands\install.py", line 257, in run
  File "C:\Program Files\WorldViz\Vizard5\bin\lib\site-packages\pip\req.py", line 151, in from_line
  File "C:\Program Files\WorldViz\Vizard5\bin\lib\site-packages\pip\download.py", line 323, in path_to_url
  File "C:\Program Files\WorldViz\Vizard5\bin\lib\urllib.py", line 1282, in quote
KeyError: u'\u2011'
Storing debug log for failure in C:\Users\mkinated\pip\pip.log
My first intuition was that I downloaded the wrong file and put it in the wrong folder, but I think I followed your instructions (See screenshot).
https://drive.google.com/file/d/0B5d...ew?usp=sharing
Any idea what went wrong?
Old 05-28-2015, 03:17 PM
Try saving the package somewhere outside of the vizard installation and give the full file path in the 'run arguments' toolbar. For example:
install C:\Users\Guest\Desktop\numpy-1.9.2+mkl-cp27-none-win_amd64.whl
Old 05-29-2015, 07:00 AM
Hi Jeff,
That worked. Thanks for the fast and great support!
External package problem from Vizard Package Manager pwsnow Vizard 1 06-13-2014 09:11 AM
