Old 09-19-2014, 10:05 AM
mshukun mshukun is offline
EXE creating a new folder
I have a problem creating a folder after compiling the code. The code below (1) creates the 'output.wav' file in the same directory as exe file. However, I would like to create "recording" folder to store the 'output.wav' file when the folder doesn't exist. How can I achieve it?
Thank you in advance.
Makiko
(1) viz.res.getPublishedPath('output.wav')
# This code doesn't work after creating exe file.
curDir = os.path.dirname(os.path.realpath(__file__))
		recfileDir = os.path.join(curDir, "recording")
		if not os.path.exists(recfileDir):
			os.makedirs(recfileDir)
Old 09-19-2014, 10:25 AM
You can use the viz.res.getPublishedPath command to determine the EXE execution path. You can use this to create files and subfolders. Here is an example:
# Get and create recording directory
recordingPath = viz.res.getPublishedPath('recording')
if not os.path.isdir(recordingPath):
	os.makedirs(recordingPath)
# Output file to recording directory
outputPath = os.path.join(recordingPath,'output.wav')
with open(outputPath,'wb') as f:
	f.write('')
Old 09-23-2014, 06:40 AM
Thank you so much!! It worked perfectly!!
Makiko
Creating a new DLS in trial license jmay Plug-in development 3 04-30-2014 09:30 AM
Creating Realistic Turns in Vizard using walkTo mikeb Vizard 1 02-28-2014 05:51 AM
Creating objects with VizLayers and returning creates duplicates....? Nyhood Vizard 1 09-11-2013 01:41 PM
Creating a road Saz Vizard 3 11-14-2008 03:45 AM
PeopleMaker - creating morphs vjonshih Vizard 4 01-02-2005 04:30 PM
