Old 04-17-2014, 06:59 AM
jmay jmay is offline
Creating a new DLS in trial license
I downloaded/installed Vizard's 90-day trial version and I'm creating a plugin for a sensor named YEI Threespace. I went through the whole process of creating the DLS in VB, I was able to get it to compile, and create a valid DLS. However, I received an error:
** Loading basicYolkMovementYEI_no_wii.py
yei.dls WorldViz Flock of Birds Driver v0.1
** WARNING: 'yei.dls' can only be used with the Development or Enterprise version of Vizard
Is there anyway to fix this?
Old 04-18-2014, 08:49 AM
UPDATE: I took the sensor zip from the creating a vizard sensor plugin thread. http://forum.worldviz.com/showthread.php?t=43
I compiled the Visual Studio solution with the updated sensor.h file (it's in the creating a vizard sensor plugin thread). I was able to compile the sensor solution and it gave me a sensor.dls file.
So I downloaded the template, created a clean .DLS and put it in the plugins folder in vizard. I still get this error:
** Loading clean_sensor_dls4-18.py
sensor.dls Worldviz Driver v1.0
** WARNING: 'sensor.dls' can only be used with the Development or Enterprise version of Vizard
** Load Time: 0.05 seconds
Old 04-28-2014, 08:59 AM
The Development or Enterprise version of Vizard is required to create plug-ins using the Vizard SDK.
Old 04-30-2014, 09:30 AM
That was exactly the problem. Thank you for the help Jeff.
License Question Sandro Holzer Vizard 4 04-02-2009 10:59 PM
continually losing network license ad_astra Vizard 1 11-30-2007 02:48 PM
Floating license server problems jrodman Vizard 2 10-30-2006 10:39 AM
For users with a floating license: Adding Vizard License Server as a Service mspusch Vizard 0 03-03-2006 11:36 AM
